Introduction
Use this guide to give your dryer a complete internal clean that restores airflow, lowers energy use and removes the lint build-up that can cause leaks, odours or even fire. You will strip the cabinet, clear every duct and reassemble a machine that runs like new.
Step 2 Clean routine user filters
Open the door and lift out the primary lint filter, removing all fibres.
Pull the secondary screen out of the door aperture and wipe it clean.
Slide the condenser cassette from the base and rinse it under running water every 10–15 drying cycles.
Step 3 Descale the condensate reservoir
Empty the water container then fill it with acidic bathroom cleaner and a handful of abrasive media such as rice.
Close the cap, shake vigorously, leave to soak and rinse until the plastic is clear.
Step 4 Remove bottom perimeter screws
Tilt the dryer forward to expose the underside of the cabinet.
Undo all cross-head screws along the lower edge using a screwdriver.
Step 5 Remove the top and front panels
Undo the two screws holding the top cover and lift the cover away.
Remove the front-frame screws, lift the panel upward and pull it toward you.
Step 6 Detach rear panel and fan housing
Undo the screws and lift away the rear cover with the fan and heater housing.
Step 7 Label and disconnect mains wiring
Disconnect the main power wires and free the harness from cable ties.
Step 8 Remove door and control fascia
Undo the Torx T25 hinge screws and lift the door off the cabinet.
Remove the three screws on the top edge of the control fascia.
Release the three plastic clips and gently pry the control panel free.
Step 9 Remove left panel and condensate housing
Undo the screw securing the left side panel and slide the panel off.
Remove the screw holding the condensate drawer housing and pull the housing forward.
Unplug the door-switch harness and cut the old cable ties that hold the loom.
Step 10 Extract drum support and condensate tube
Remove the small screws on each side of the rear drum support bracket.
Detach the condensate tube and lower the support away from the drum.
Step 11 Inspect and clean the felt seal
Check the drum felt for wear; if intact brush out trapped lint instead of replacing it.
Step 12 Remove heater fan and pump assembly
Unplug the temperature and pump connectors noting that the pump uses three contacts.
Use a 13 mm wrench to loosen the nut and slide the fan wheel off its shaft.
Remove the four screws securing the heater plate and lift the heater out.
Cut the remaining cable tie to free the harness completely.
Step 13 Clean internal components
Vacuum lint from the heater elements and enclosure using a narrow nozzle and brush.
Scrub stubborn deposits with a steel brush or kitchen scouring pad until metal surfaces are clear.
Remove the pump impeller and clean the magnet and housing so water can flow freely to the tank.
Step 14 Reassemble the dryer
Refit the heater with its four screws then slide the fan wheel on and tighten the 13 mm nut.
Reinstall the drum support bracket condensate tube and side panels keeping wires routed as photographed.
Secure the harness with new cable ties and reconnect the mains wires according to your markings.
Step 15 Test the appliance
Plug the dryer in and run a short programme to confirm drum rotation airflow and absence of leaks or smells.
Your dryer is now clear of lint, moisture paths are open and the heater is safe. Keep the filters clean after every cycle and repeat this deep service whenever airflow drops or odours return.
