This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓Hello! Today, I will teach you how to make a part with a Magis 3D printer (from Dagoma).
To do this, you will need:
- the Magis 3D printer from Dagoma
- a filament (a PLA or polylactic acid filament)
- a thin blade to be able to detach the print from the machine
- the Cura by Dagoma application
- an SD card
-To start, you can go to Tinkercad or another software that allows you to visualize the part to be printed (personally, I will be using Tinkercad for this tutorial).
-Next, create a new design, then import or create the desired object, and then export the project.
-To start, you must export your object in STL format
-Then go to Cura and drag your project in STL format directly into the application
-Then click on Prepare print after carefully verifying that your part is compliant.
To reassemble your device, follow the instructions in reverse order.
