How to get (almost) of your data with just movable.sed & Nintendo 3DS Folder!
  1. How to get (almost) of your data with just movable.sed & Nintendo 3DS Folder!, Sleep Mode: step 1, image 1 of 1
    • Power off your modded 3DS/2DS.
  2. How to get (almost) of your data with just movable.sed & Nintendo 3DS Folder!, Downloading The Script: step 2, image 1 of 1
    • Take out your 3DS sd card, Download the movableover script (here on your computer) https://raw.githubusercontent.com/nh-ser... just make sure you do the (save as) then go to your SD cards folder, gm9, then go to scripts. Add that file from there. If its not called MovableMoveover.gm9 then rename it to that.
  3. How to get (almost) of your data with just movable.sed & Nintendo 3DS Folder!, Booting to GodMode9: step 3, image 1 of 1
    • Put your SD card back into your 3DS, had boot into GodMode9, (how is to do start+power) when turning on.
    • Now, if you are booted on, it shows all of ur drives with a green line on top, then you have boot on to there. (If it asks you to set the rtc time, then do that. To the current time)
  4. How to get (almost) of your data with just movable.sed & Nintendo 3DS Folder!, Injecting the OLD movable: step 4, image 1 of 1
    • NOW! Warning, this part could brick your device!
    • Go to the drive, (its the 2nd under your SD card drive) it should be the SysNand CTRNAND. Click A on that one. Go to the private folder (the 4th folder) now, see the movable? It should JUST say that. Nothing else. Click on it (A) go all the way down to copy to 0:/gm9/out. click A. It should be copied.
    • alrighty, remember the movable (not for THIS system) for for the one that other 3DS? (The one to recover all of our data?) Put that in the -root- of your sd card.
    • GO TO CTRNAND, THEN PRIVATE. THEN DO R+X BUTTON ON THAT FILE TO RENAME IT TO "movable.sed" PUT THE FOLLOWING INPUT CODES ON THE SCREEN AFTER YOU RENAME IT.* once that is done, Go back, (B) 2 TIMES. Click the home menu button, it should have 6 options, go to the scripts one. Now go to the movable one. Then click on the movable.
    • Now do start to reboot your console. If you did this right, your system seems like its new, this is part of the process. get to the home menu, by doing the setup. Noe, once your there. You MAY see some of your "system" data back, but the menu setup is still the same, now, we need to link your NNID.
    • Go to System Settings, go to Nintendo Network ID Services (idk if its called that lol) then enter your email address for THAT id, and your password for it, and your network ID, if you have an error message that its linked on another system..
    • Then go to this website, https://en-americas-support.nintendo.com... (it may take a day or two, but the reason why we are linking this s to get your main Mii back, but ALSO your apps on the eshop to redownlod them to restore ur data (you'll see after the next step)
    • If you linked your Nintendo ID, Great! Go to the eshop, then settings, redownloaded software, then redownload ALLL of your apps that you had before. Once done, go to the home menu, go to the home menu icon, (on the upper left corner) and then, go to the home menu layout, then select the current one you USED to have.
    • Note! You won't recover everything from your save data apps but at least THE IMPORTANT ONES.
    • Now, download or go to FBI, then go to your ext save data, then you will see all of your apps! Then click one you need, then.. See that save data folder? That has your save data! :D click on it.. But.. If there's none.. Dont worry! Just the 3DS does not know where it is exactly.
    • If there is files, then copy those all and go back to the fbi menu, then go to the apps selection, now, go to the files that you paste on THAT save data app, then paste them on to that app! (Ok, if you go to the save data on the new redownloaded app and says it cannot, open the new redownloaded app, then go back to fbi, it shall open that new app.
    • Once you paste those files into the new app, then just exit FBI, then go to that app! If it Shows your data yay!..now do that to the other apps too! (I don't know the answer to what I said if your save data files are not "there" but im sure since it says it exists sooo..) and yes, your gonna sadly restart most of your system data, but update soon..
And you are (pretty much) DONE! :D enjoy your data some of it... Back! Anyways, contact me if you want another other issues with this guide!
WyattDYT
1 Reputation
1 Guide authored
Kid fixers Member of Kid fixers
Community
188 Members
270 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 49
All Time: 149
