How to fix stick drift on the Oculus Quest 2
  1. How to fix stick drift on the Oculus Quest 2, Buy some isopropyl alcohol: step 1, image 1 of 1
    • Buy isopropyl alcohol, the higher the percentage the better it will work (this liquid will not damage electronics and is made to clean them).
    • Pour the alcohol on the joy stick (I would pour quite a bit on to make sure you can get all that dust) making sure it goes under and into the device, now move around the joy stick and work the alcohol into the underneath of the joystick (this removes the dust that causes stick drift).
    • Now leave the controller for about and hour to make sure all the alcohol evaporates to prevent damage. (You can leave it in a warm environment or use a hair dryer to heat up around the joy stick to be 100% certain. You won't have to heat it up very hot as this liquid evaporates very quickly).
    • Now enjoy no stick drift however this process will have to be repeated once dust forms again under the joy stick.
2 other people completed this guide.
kai jones
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 96
All Time: 1,466
