Introduction
This guide will tell you how to prevent somebody to steel your money and/or identity when your credit or debit card expired or is replaced.
Note this can NOT be undone
Take a magnet and swipe it over the magnetic strip minimum 10 times. Take something sharp and make hole where the chip was.
  • Take a magnet and swipe it over the magnetic strip minimum 10 times.
  • Take something sharp and make hole where the chip was.
Use a pair of scissors and cut the card into thin strips. See the photo. It is not recommended to have the strips thicker then 2mm.
  • Use a pair of scissors and cut the card into thin strips.
  • See the photo.
  • It is not recommended to have the strips thicker then 2mm.
Saving and collecting the little gold emblem could make you some money in the future.
Clifton Linne - Reply
The distance you see in the blue circle is not recommended to be more then 2mm. Cut the card into many small parts as seen on the photo.
  • The distance you see in the blue circle is not recommended to be more then 2mm.
  • Cut the card into many small parts as seen on the photo.
  • It is recommended to have a box/tin to prevent the parts to fly anywhere.
Look on the floor and on the table and see if you lost some parts of the card
  • Look on the floor and on the table and see if you lost some parts of the card
  • If you found some, cut them also.
  • See previous steps.
  • Take some parts in the trash at home and some other an other place, eg work, public area, etc.
  • Recomanded min 2 places
    • Taking it to the neighbor will not increase security a lot.
Finish Line
23 other people completed this guide.
Truls Zhong Konstali
1,267 Reputation
1 Guide authored
7 Comments
You didn't mention how to destroy the chip. You need to destroy the chip also. Otherwise this method is very good (excellent if it wasn't a chip card.)
thealy449 - Reply
Would've been easier to burnt the CC to ashes . Now that's one and only one way that you will keep it from falling in to the anyone's scam, fraud...
Hiram Pabon - Reply
Please correct some typo but yes you got the
Hiram Pabon - Reply
Now for anything that has 2 do w/a/pc's smartphone has a has a has a.
Hiram Pabon - Reply
Rabitts take the hard drive and burnt it to a crispy ashes.
Hiram Pabon - Reply
Fire destroyed anything
Hiram Pabon - Reply
Destroys anything
Hiram Pabon - Reply
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 201
All Time: 8,029
