How to Upgrade the Back Ports to USB-C on a GameBoy Advance
Video Overview
    1. How to Upgrade the Back Ports to USB-C on a GameBoy Advance, Back Ports: step 1, image 1 of 1
      • Turn off the Game Boy Advance SP completely. Then start cleaning the ports located on the back side of the case.
      • Use a cotton swab dipped in alcohol to gently scrub the inside of the port.
      • Do NOT apply too much pressure or use anything sharp to clean the ports.
      Ask FixBot
    2. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 2, image 1 of 2 How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 2, image 2 of 2
      • Use a Y00 screwdriver to remove the six Tri-Wing 1.5mm screws as you carefully disassemble your Game Boy into 4 parts: console, battery, back panel, and motherboard. The 6 screws are highlighted in the red circles.
      • The next few steps require knowledge of soldering and soldering safety guidelines. We strongly recommend that you review this video on how to safely solder.
      Ask FixBot
    3. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 3, image 1 of 1
      • Next, desolder the back port (highlighted in the red box) from the motherboard using a desoldering pump.
      • Take caution of the other parts of the motherboard as you desolder.
      • Clean off any remaining solder on the motherboard when you finish.
      Ask FixBot
    4. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 4, image 1 of 1
      • Align your USB-C port in place and ensure the bottom is facing downward.
      • Prepare the solder and iron for the next step.
      Ask FixBot
    5. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 5, image 1 of 2 How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 5, image 2 of 2
      • Solder the sides that were previously connected to the old port.
      • After it is secured on both sides, solder the 4 metal pins on the back of the new USB-C port.
      • Once again, be careful not to damage/apply heat to any of the other parts of the motherboard.
      Ask FixBot
    6. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 6, image 1 of 1
      • To test for a successful connection, turn on the device.
      • If it doesn't turn on, ensure the port is connected to the correct points. If it isn't, use your soldering iron to solder the correct metal points.
      Ask FixBot
    7. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: step 7, image 1 of 1
      • Follow Steps 1 and 2 in reverse to reassemble.
      Ask FixBot
3 other people completed this guide.
Ifunanya O
106 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 112
Past 30 Days: 440
All Time: 1,695
