Fix Your Stuff
Right to Repair
Store
Introduction
REWA tells you how to upgrade your iPhone 6s 16GB memory storage to 128GB.
Video Overview
  1. Run function test first. All going well. Check current storage: 16GB. Restore iPhone via iTunes.
    • Run function test first. All going well.
    • Check current storage: 16GB.
    • Restore iPhone via iTunes.
    • Insert the SIM card and activate the phone.
  2. Take apart the phone and take out the logic board.
    • Take apart the phone and take out the logic board.
    • Attach the logic board to the PCB Holder. Then detach the NAND flash chip from the board. Clean the bonding pad afterwards.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Connect the PCIE NAND Flash Chip Programmer with computer. Then press the on/off button.
    • Connect the PCIE NAND Flash Chip Programmer with computer. Then press the on/off button.
    • First, we need to read data of the original 16G NAND flash chip with the programmer and backup the data.
    • Then write the saved data to a brand new 128G NAND flash chip with the programmer.
  5. Once done, reball and then solder the 128G NAND flash chip onto the logic board.
    • Once done, reball and then solder the 128G NAND flash chip onto the logic board.
  6. Restore the phone via iTunes.
    • Restore the phone via iTunes.
    • Run function test. All going well.
    • Check the storage: 128GB
Warm Reminder:
1. The PCIE NAND Flash Chip Programmer involved is mainly applied to iPhone 6s / 6s Plus / SE / iPad Pro.
2. This upgrade may not be suitable for doing at home, skilled repair-man is required.
3. It’s about to upgrade iPhone 6s internal memory, but not expansion cards or plug-in memory or sort of.
4. Hi-speed performance, the 128GB brand new flash drive enjoys the same-level fast speed as previous 16GB.
5. The empty bonding pads caused when taking off the old flash drive will not affect the performance.
6. Apple official after-sales support does not accept the phone repaired by third-party.
7. There is a possible risk for the upgraded iPhone. If this upgrade iphone storage technology was widely applied, Apple official may take some measures to stop this.
4 other people completed this guide.
Phryne
10,251 Reputation
80 Guides authored
0 Comments
Past 24 Hours: 29
Past 7 Days: 247
Past 30 Days: 1,009
All Time: 4,078
