How to Unclog a PETLIBRO Dockstream Smart Fountain
  1. How to Unclog a PETLIBRO Dockstream Smart Fountain, How to Unclog a PETLIBRO Dockstream Smart Fountain: step 1, image 1 of 2 How to Unclog a PETLIBRO Dockstream Smart Fountain, How to Unclog a PETLIBRO Dockstream Smart Fountain: step 1, image 2 of 2
    • Unplug the fountain and pour out all the water.
    • Remove the fountain from the wooden charging base. Set the fountain next to the base.
  2. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 2, image 1 of 1
    • With your finger on the white latches press up and away to unlatch the stainless steel basin from the fountain.
    • You should see the motor at the bottom center of the water tank.
  3. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 3, image 1 of 1
    • Take the motor out of the water tank.
    • Remove the grey tower from the main water pump unit.
  4. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 4, image 1 of 1
    • Take the main water pump unit apart by separating the sponge holder (the smaller piece with holes) from the motor housing unit (the larger piece).
    • Remove the black sponge.
  5. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 5, image 1 of 3 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 5, image 2 of 3 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 5, image 3 of 3
    • You may need to clean out the hairs stuck to the sponge holder, water tank, or other parts.
    • To do this, get a wooden kabob skewer and gently pick the dirt and hair out. Use a paper towel for removing larger pieces of dirt and hair that you have picked out with the skewer.
    • The first picture shows the motor housing; the second picture shows the sponge holder.
  6. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 6, image 1 of 1
    • With a damp paper towel, clean the inside of the water tank.
  7. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 7, image 1 of 1
    • With a different damp paper towel, clean the stainless steel basin.
  8. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 8, image 1 of 1
    • Rinse the stainless steel basin with water.
  9. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 9, image 1 of 1
    • Wash the steel basin with a sponge and soap. Then rinse again.
  10. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 10, image 1 of 2 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 10, image 2 of 2
    • Rinse the lid of the filter housing unit.
    • Wash the lid off the filter housing unit with a sponge and soap.
  11. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 11, image 1 of 1
    • Rinse the spout with hot water.
  12. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 12, image 1 of 1
    • Rinse the grey tower.
  13. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 13, image 1 of 1
    • Bring the water tower to the sink.
  14. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 14, image 1 of 2 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 14, image 2 of 2
    • Fill with cold water to the black fill line.
  15. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 15, image 1 of 2 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 15, image 2 of 2
    • Now that the sponge holder is clean insert the black sponge.
    • Make sure the black sponge is level with the surface of the sponge holder.
  16. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 16, image 1 of 1
    • Push the sponge holder into place on the motor housing unit.
    • You should hear a click sound when they are properly connected.
  17. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 17, image 1 of 1
    • Set the grey tower next to the water pump.
  18. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 18, image 1 of 1
    • Connect the base of the tower to the tube closest to the black sponge.
  19. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 19, image 1 of 1
    • Locate the lock (rectangle shaped gap) at the base of the sponge holder.
  20. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 20, image 1 of 1
    • Place the water pump into the water tank. Look for the rectangle shaped nub at the bottom of the water tank.
  21. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 21, image 1 of 1
    • Snap the lock onto the nub at the bottom of the water tank.
  22. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 22, image 1 of 1
    • Place the stainless steel basin on top of the water tank.
  23. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 23, image 1 of 2 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 23, image 2 of 2
    • Get a fresh filter and place the hole of the filter over the tube at the base of the filter housing unit.
    • Make sure the filter is pressed down into the filter housing base.
  24. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 24, image 1 of 2 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 24, image 2 of 2
    • Take the cleaned lid off the filter housing unit and place it over the base of the filter housing unit so that the tube in the base is right below the hole in the lid.
    • You should hear a click sound when the lid is securely in place.
  25. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 25, image 1 of 2 How to Unclog a PETLIBRO Dockstream Smart Fountain: step 25, image 2 of 2
    • Take the cleaned spout and place the base of the spout into the hole of the lid.
  26. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 26, image 1 of 1
    • Always remember to latch the stainless steel basin to the top of the water tank when done.
  27. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 27, image 1 of 1
    • You can now plug in the fountain to an outlet.
  28. How to Unclog a PETLIBRO Dockstream Smart Fountain: step 28, image 1 of 1
    • The cleaned fountain is now ready for use.
Finish Line
Joshua Bohumil
397 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 42
All Time: 368
