Introduction
Go to step 1 ↓Use this guide to troubleshoot a warmer-zone burner on a Kenmore or Frigidaire-family glass-top electric stove that will not heat. The warmer-zone element provides low 120 V heat to keep food warm on the cooktop. Use this guide to determine whether the warmer-zone element or switch has failed. Compare the wire colors and terminal layout with the wiring diagram for your specific stove before replacing parts.
Step 1 Prepare the stove safely
Turn every burner control off and let the glass cooktop cool completely.
Unplug the stove from the wall.
Step 2 Access the warmer zone burner and switch
Remove the glass cooktop enough to reach the warmer-zone burner terminals.
Open the control area enough to reach the back of the warmer-zone switch.
Step 3 Read the burner terminal diagram
Use this burner-terminal layout from left to right: element terminal, temperature-switch terminal, temperature-switch terminal, element terminal.
The two outside terminals connect to the warmer-zone element winding.
The two center terminals connect to the built-in temperature switch.
Step 4 Understand the temperature switch circuit
Use the temperature switch to understand the indicator circuit.
One temperature-switch terminal carries constant 120 V whenever the stove is powered.
When the element heats up, the temperature switch closes.
The closed switch sends voltage back through the other center wire for the warm-burner indicator circuit.
Step 5 Read the warmer zone switch diagram
Use this switch layout: black hot feed, white neutral feed, purple burner outputs, and purple indicator jumper.
The black and white wires bring 120 V into the warmer-zone switch.
One neutral wire jumps to the indicator light.
When the switch is on, 120 V leaves the switch on the two purple wires that feed the warmer-zone element.
Step 6 Understand the indicator light
Use the warmer-zone indicator to tell whether the surface is still hot.
The same light works as both the element-on indicator and the warm-burner indicator.
When the switch is on, the switch terminal feeds the purple jumper and turns the light on.
When the switch is off, that switch terminal is no longer powered.
If the burner is still warm, the closed temperature switch feeds the purple jumper and keeps the light on.
Step 7 Set up the multimeter
Confirm that the stove is unplugged.
Set a multimeter to ohms or continuity.
Use the ohms reading for diagnosis, not a powered voltage test.
Step 8 Test the warmer zone element
Place one multimeter lead on each of the two purple wires that go to the warmer-zone burner element.
Read the resistance on the meter.
Step 9 Use the troubleshooting flowchart
Use this troubleshooting flow: no heat → unplug the stove → set the meter to ohms → test across the two purple burner wires.
If the meter reads near 134 ohms and the burner still does not heat, the element is good and the warmer-zone switch is faulty.
Replace the warmer-zone switch if the element has a good ohm reading but never turns on.
If the meter reads OL, the warmer-zone element circuit is open.
Replace the warmer-zone burner element if the meter reads OL.
Step 10 Test the switch continuity
Keep the stove unplugged and the warmer-zone switch accessible.
Identify the black and white 120 V input wires and the two purple output wires from the wiring diagram or your recorded wire positions.
Check continuity from the switch input side to each matching purple output with the control set to Off.
The switch output should read OL with the control off.
Turn the control on and check the same input-to-output paths.
The switch output should change from OL to continuity with the control on.
Replace the warmer-zone switch if the output stays OL when on and the element reading is good.
Step 11 Replace the faulty component
Install a matching warmer-zone burner element if the element reads OL.
Install a matching warmer-zone switch if the element reads near 134 ohms but the switch does not send continuity to the purple output wires.
Make sure each connector seats firmly on its terminal.
Step 12 Check normal operation
Use an infrared thermometer to compare the surface temperature if the burner heats but seems weak.
Switch the warmer zone to high only if the low setting responds normally.
After the repair, confirm the warmer zone heats on low and high, and confirm the indicator light turns on when the control is on or the burner remains warm. Repair didn't go as planned? Ask our Answers community for help.
