Shop the Holiday Gift Guide
How to Troubleshoot and Test a Kenmore Stove 6 Inch Top Burner
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
79
All Time:
239
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to diagnose a 6 inch top burner that will not heat on a Kenmore glass-top stove. This burner, also called a radiant element or surface element, is controlled by a burner switch and protected by a high-limit temperature probe. These resistance tests help you determine whether the failed part is the burner or the switch. This guide was written around the right rear 6 inch burner on a Frigidaire/Kenmore-style glass-top stove, but wire colors and access may vary slightly by model.
Parts
Tools
      • Turn all burner controls off and let the glass cooktop cool completely.
      • Unplug the stove or shut off the breaker before accessing any wiring.
      • Stove wiring can carry dangerous voltage, so do not touch wires or test resistance while power is connected.
      • Access the back of the right rear burner switch and the wiring for the 6 inch top burner.
      Ask FixBot
      • Locate the two blue wires connected to the 6 inch top burner.
      • Those two blue wires feed power from the burner switch to the element.
      • Locate the small glass temperature probe on the burner assembly.
      • That probe opens the contact between one blue wire and the element if the burner gets too hot.
      • This high-limit function helps protect the glass cooktop from overheating.
      Ask FixBot
      • Identify the hot-surface indicator circuit that runs through the temperature probe.
      • When the glass gets too hot to touch, the probe closes the hot-surface circuit and sends 120 V to the indicator light.
      • The black wire from the probe and the white neutral wire complete the hot-surface indicator circuit.
      • The purple wire powers the element-on indicator whenever the burner control is on.
      Ask FixBot
      • Look at the back of the right rear burner switch.
      • The red and black wires bring power into the switch.
      • The two blue wires run from the switch to the burner and control how it cycles.
      • Keep each wire matched to its original terminal if you remove the switch.
      Ask FixBot
      • Use the switch setting to understand how the burner cycles.
      • At low heat, the switch opens sooner with a small amount of current and heat at the internal bimetal contact.
      • At higher settings, the switch applies more pressure to the contact, so it takes more current and heat before the contact opens.
      • At high heat, the switch contact stays closed.
      • On high, the glass temperature probe still limits the maximum burner temperature.
      Ask FixBot
      • Confirm that the stove is still unplugged or switched off at the breaker.
      • Set a multimeter to ohms.
      • Touch one probe to one blue wire that goes to the burner.
      • Remove the other blue burner wire from the switch.
      • Touch the second probe to the removed blue burner wire.
      • Measuring resistance on a live circuit can shock you and damage the meter.
      Ask FixBot
      • Read the multimeter while both probes touch the two blue burner wires.
      • A reading of about 45 ohms means the high-temperature probe contact is closed and the burner windings are good.
      • An open reading, infinite resistance, or no continuity means the high-temperature probe switch or the element windings have failed.
      • Replace the 6 inch top burner if the burner circuit fails this resistance test.
      Ask FixBot
      • Use the burner resistance result to diagnose the switch by elimination.
      • If the burner reads about 45 ohms but still does not heat during use, replace the burner switch.
      • Do not replace the burner when it tests good and the no-heat symptom points to the switch.
      Ask FixBot
      • Replace the 6 inch top burner only when the blue-wire resistance test shows an open burner circuit.
      • Replace the burner switch only when the burner circuit tests at about 45 ohms and the burner still does not heat.
      • Do not bypass the temperature probe or either indicator-light circuit.
      • Reconnect every wire to its correct terminal before restoring power and testing the burner.
      Ask FixBot
Reassemble any panels you opened, restore power, and test the burner on a controlled setting. Repair didn't go as planned? Ask our Answers community for help.
Author
with
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 79
All Time: 239
