How to Troubleshoot a Whirlpool Cabrio Dryer Not Heating
Views: 1.8K
View statistics:
Past 24 Hours:
15
Past 7 Days:
62
Past 30 Days:
290
All Time:
1,818
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 3 hours
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
If a Whirlpool Cabrio-style electric dryer runs but won’t heat, the problem is often a loss of 240 V power, a failed heater component (thermal cutoff, thermostat, thermistor, thermal fuse, or heating element), or restricted airflow from lint buildup. This guide shows how to open the dryer, test the heater circuit with a multimeter, clean common lint choke points, and replace the heating element assembly used on this front-accessible Cabrio-style design.
      • Turn off the dryer’s power at the breaker and unplug the cord before opening any panels.
      • WARNING: Electric dryers use 240 V, which can seriously injure or kill you if you contact live wiring.
      • Wear cut-resistant gloves because the cabinet edges and internal panels can be sharp.
      • Take photos of every wire connection you remove so reassembly is unambiguous.
      Ask FixBot
      • Use a multimeter to verify the dryer is receiving about 240 V at the terminal block at the back of the dryer.
      • If you don’t have close to 240 V, the dryer won’t heat even if every internal part is good.
      • If you only read about 120 V, the dryer likely has a dead leg and the issue is electrical, not a dryer fault.
      • Reset the breaker, and inspect the receptacle and dryer cord if the voltage is incorrect.
      • WARNING: Live-voltage testing is hazardous, so stop and call a professional if you aren’t fully comfortable working around energized 240 V circuits.
      Ask FixBot
      • Use a Phillips screwdriver to remove the two long screws that secure the console, with one screw on each side.
      • Push the console forward and up to release it from the cabinet and expose the control board area.
      • Use a 1/4" nut driver to remove the screw securing the interface board housing.
      • Press the plastic tab in the middle of the metal housing to release and remove the board.
      • Depress the six plastic tabs around the board cover to open it and inspect the underside near the relays for burn marks or failed solder joints.
      • Heat-damaged relays can prevent heating or prevent the dryer from turning on at all.
      • Reconnect the harnesses exactly as found because the connectors are keyed and should only fit one way.
      Ask FixBot
      • Open the door and slide a putty knife under the top seam to press the clips on the left and right sides.
      • Lift the top panel to access the drum area.
      • Brace the top panel so it doesn’t fall backward and strain the hinges.
      Ask FixBot
      • Use a 5/16" or 1/4" nut driver to remove the two screws securing the front panel area.
      • Disconnect the door switch wire harness, using a putty knife to help release the connector if space is tight.
      • Roll the door panel forward, then lift it up and away to remove it.
      • Don’t bend the small metal catches at the bottom because the front panel sits on them during reassembly.
      Ask FixBot
      • Unclip the moisture sensor connector in the lower right corner before removing the bulkhead.
      • Remove the six bulkhead screws, with four on the bulkhead and two at the very bottom near the blower housing.
      • Pull the bulkhead forward and remove it, and be ready to catch it if the drum pushes it outward.
      Ask FixBot
      • Push the idler pulley toward the casing to create slack and slip the belt off the motor spindle.
      • Use the belt to lift the drum up and out through the cabinet slots.
      • Inspect the idler pulley wheel, spring, and assembly for damage because failures can cause running or startup issues.
      Ask FixBot
      • Pull the wires off the thermal fuse terminals.
      • Set the multimeter to continuity mode and touch the probes to the fuse terminals.
      • Replace the thermal fuse if you don’t get continuity.
      • Some dryers of this style won’t run at all if the thermal fuse is open.
      Ask FixBot
      • Pull the wires off the thermistor terminals.
      • Set the multimeter to resistance mode and measure the thermistor’s resistance.
      • Compare your reading to the value chart in the technician’s manual, and aim for about ±5% at your room temperature.
      • A reading around 12.52 kΩ at about 70 °F is considered normal for this style.
      • Don’t use continuity mode on a thermistor because it won’t read correctly even when the thermistor is good.
      • If you replace the thermistor, remove its two mounting screws and move the wires to the new part in the same positions.
      Ask FixBot
      • Inspect the blower housing opening for packed lint and debris while the front is open.
      • Remove all lint and debris from the blower housing area before reassembly.
      • If the drum feels warm but clothes don’t dry, a lint-restricted blower housing is a common cause on this style.
      • Caution: Lint buildup can overheat the heater housing and cause safety devices like the thermal cutoff to trip.
      Ask FixBot
      • Locate the heater can assembly and identify the heating element, the thermostat with multiple wires, and the thermal cutoff.
      • Set the multimeter to continuity mode to test each heater component for an open circuit.
      • Remove at least one wire from the component you’re testing to prevent backfeeding and false positives.
      • Take a clear photo of the wire routing because this area is a tight cluster of connectors.
      Ask FixBot
      • Remove one heating element wire and test continuity across the element’s two terminals.
      • Expect roughly 10 Ω on the element, with about ±10% variation.
      • Test for a grounded element by probing from an element spade terminal to the metal canister in multiple spots.
      • Replace the element if you get any continuity to the canister because the coil may be touching the housing.
      • Reconnect the wires exactly as found when you finish testing.
      Ask FixBot
      • Remove one wire from the thermostat and use continuity mode to verify the thermostat is closed.
      • Test the thermal cutoff the same way by removing either wire and checking for continuity.
      • Replace any heater component that doesn’t show continuity in this test.
      • The thermal cutoff is a common no-heat failure on this style and often indicates overheating from lint restriction.
      • If you replace heater sensors, remove the top and bottom mounting screws and transfer the wires so the routing stays correct.
      • Make sure a wire routes from the thermostat down to the heating element because incorrect wiring can prevent heat.
      Ask FixBot
      • Use a 1/4" nut driver or socket to remove the single screw that secures the heater canister to the dryer.
      • Use a ratchet if a screwdriver can’t reach the screw straight due to the surrounding metal.
      • Pull the heater canister straight out after removing the screw.
      • Note that an internal screw holds the plate to the can, so the plate may stay attached while you remove the canister.
      Ask FixBot
      • Remove the clamshell perimeter screws, with four on one side and two on the other side.
      • Open the clamshell housing and lift the heating element out.
      • Use small pliers to bend back the tiny retaining tabs at the element’s spade connector area if they block removal.
      • Install the new element in the same position, close the clamshell, and reinstall all screws.
      • Some versions use Phillips screws and some use 1/4 inch screws, so match your driver to what you have.
      Ask FixBot
      • Remove the single screw that retains the heating element inside the canister.
      • Pull the element out of the canister, using a ratchet extension if you need more leverage.
      • Slide the new element into the canister and secure it with the retaining screw.
      • The element fit can be tight, so push it in straight to avoid bending the housing.
      Ask FixBot
      • Use the multimeter to check continuity through suspect wiring if you’ve tested the heater parts and still have no heat.
      • Consider professional service if you suspect a motor switch, a centrifugal switch, or a control output problem.
      • WARNING: Advanced troubleshooting that involves tracing live 120 V or 240 V through the circuit should be done by someone trained and comfortable working on energized equipment.
      Ask FixBot
      • Set the drum back onto the rear rollers and route the belt around the idler pulley.
      • Turn the drum slightly as needed to help it align while reinstalling the bulkhead.
      • Reconnect the moisture sensor, reinstall the bulkhead, and secure it with six screws.
      • Set the front door panel onto the lower catches, align the lower corners carefully, and reinstall the two top screws.
      • Reconnect the door switch wire harness before closing the cabinet.
      • Lower the top panel until the clips latch, and reinstall the console if removed.
      Ask FixBot
If the dryer heats normally after you correct the failed heater, fuse, thermostat, thermistor, or supply problem, finish by checking airflow so the same overheating fault does not return. If the heat circuit still tests good but the dryer stays cold, continue with wiring and control diagnosis rather than guessing at more parts. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,149 Reputation
224 Guides authored
1 Guide Comment
Explains very well even for inexperienced ppl. Thank you
Patricia Persell - Reply Share
Past 24 Hours: 15
Past 7 Days: 62
Past 30 Days: 290
All Time: 1,818
