Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓Use this guide to diagnose a Kenmore or Frigidaire glass-top stove with a 6 inch Simmer Select burner that will not heat. The Simmer Select position uses the same burner element and main burner switch as a standard 6 inch burner, but adds a Simmer Select switch and control board for finer low-heat control. These tests help you determine whether the failed part is the burner, the switch, or the Simmer Select control board. This guide was written around a Kenmore/Frigidaire glass-top stove with a 6 inch Simmer Select burner, but wiring and access can vary slightly by model.
Step 1 Disconnect power
Wait for the glass cooktop, burner, and control board to cool before touching any parts.
Step 2 Identify the Simmer Select burner
Find the 6 inch Simmer Select burner and compare it with the regular 6 inch burner on the other side.
Identify the Simmer Select button or selector switch near the burner control.
Pressing the button in turns Simmer Select on, and releasing it turns Simmer Select off.
With Simmer Select off, the burner works like a normal burner.
Step 3 Understand the two heat modes
In normal mode, the burner control covers low through high and supplies 240 V to the burner.
Normal high heat gives the burner enough power for tasks like boiling water.
In Simmer Select mode, the burner runs at 120 V for lower heat.
Simmer Select spreads the low-temperature range across Low through 4 on the control.
Step 4 Read the switch layout
Expose the back of the burner switch and the Simmer Select switch enough to see the wires and terminals.
The two yellow wires run from the burner switch to the burner element.
The purple wire feeds the burner-on indicator light.
The hot-surface wire comes from the other side of the burner and powers the indicator above the switch when the burner heats.
The extra yellow wire feeds the Simmer Select switch, and the two red wires leave that switch.
Step 5 Review the burner wiring
Use the circuit layout to understand the Simmer Select control path.
L1 passes straight through the burner-switch circuit.
With Simmer Select off, L2 passes straight through the board so the switch still gets the full 240 V supply.
With Simmer Select on, the board routes L2 through a resistor load before sending it back to the switch.
Step 6 Review the control board layout
Locate the Simmer Select control board in the L2 path.
The red signal wire brings 120 V from L1 to tell the board that Simmer Select is on.
The neutral wire feeds the transformer, and the transformer powers the relay.
When the relay is off, incoming L2 passes straight through the board.
When the relay is on, L2 is routed through the resistor load before it returns to the burner circuit.
Step 7 Test the burner resistance
Set a multimeter to ohms.
Place one probe on each of the two yellow wires on the back of the burner switch that go to the burner.
A good 6 inch burner should read about 45 ohms.
An OL or open reading on those two yellow burner wires means the burner is bad and needs replacement.
Step 8 Test the control board L2 path
Leave Simmer Select off for this continuity test.
Place one probe on the red L2 wire where the power cord attaches to the range.
Place the other probe on the L2 terminal on the burner switch.
An OL reading means there is no complete circuit from cord L2 to switch L2, so the control board is bad and needs replacement.
Step 9 Test the switch by elimination
Replace the 6 inch burner element if the burner resistance test shows OL or an open circuit.
Replace the Simmer Select control board if the burner tests good but the L2 path through the board reads OL.
Replace the burner switch if the burner tests good and the control-board L2 path tests good, but the burner still does not heat.
Step 10 Replace the burner element
Open the cooktop enough to reach the underside of the 6 inch burner element.
Disconnect the two yellow burner wires from the old element.
Remove the old burner element from its mounts while keeping any brackets or insulators in their original positions.
Install the replacement 6 inch burner element in the same position.
Reconnect the two yellow burner wires to the same terminals they used on the old element.
Step 11 Check operation after repair
Turn the burner on in normal mode and confirm that it heats through the low-to-high range.
Press the Simmer Select button in, set the burner around 4, and confirm that it runs at the lower Simmer Select heat level.
Turn the burner off and let the glass cooktop and control board cool before closing any remaining access.
Replace only the part that failed the tests, and keep the wire photos with the appliance records for future service. Repair didn't go as planned? Ask our Answers community for help.
