Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓If a Kenmore (Frigidaire-built) gas oven won’t heat, the problem is often a failed or weak oven igniter. This guide walks through simple checks to confirm you have gas supply and a working broiler, then shows how to access and replace the bake igniter, including removing and reinstalling the oven door. It also covers how to test the oven safety valve and how to measure igniter amperage when the igniter glows but the burner still won’t light.
Parts
Tools
Step 1 Prepare the stove for safe troubleshooting
Turn off the oven controls, and let the oven cool completely before reaching inside.
Step 2 Confirm the gas supply and cooktop operation
Verify other gas appliances in the home run normally.
Test the cooktop burners to confirm the stove is getting gas.
Step 3 Test broil to narrow down the problem
Set the oven to broil and look for normal heat operation.
Step 4 Check the bake igniter glow
Set the oven to bake and look for a bright red or orange glow at the lower part of the oven.
Plan on replacing the bake igniter if there is no glow, because the igniter is the cause most of the time.
Step 5 Remove the oven door
Open the oven door and pull the locking tab down toward the door on each hinge.
Push the door back toward the oven, then lift the door up and pull it out of the chassis.
Step 6 Remove the oven bottom panel
Remove the two thumb screws inside the oven, located at the back left and back right.
Pull the main oven panel up, then back, then out to remove it.
Step 7 Remove the oven baffle to expose the burner and igniter
Remove the two screws at the front of the oven baffle.
Pull the baffle up slightly, then pull it out to reveal the igniter and the gas burner bar.
Step 8 Remove the igniter from the burner assembly
Remove the two screws on the right side of the housing that hold the igniter in place.
Remove the two burner bar screws, with one on the back wall and one at the front that’s accessible before the baffle is removed.
Lift the burner bar up and out once it’s free-floating.
Step 9 Choose a compatible replacement igniter
Trace the igniter wires to the harness or connection that provides power to the igniter.
Step 10 Install the new igniter and connect the wiring
Mount the new igniter to the burner bar, moving the shield slightly if needed for clearance.
Cut the wires to the old igniter about halfway so the original harness stays physically in place.
Trim the wires on the old harness to expose clean wire from the cloth insulation.
Mate the harness wires to the new igniter wires using ceramic wire nuts.
Step 11 Reinstall the burner bar and secure the wiring
Reinstall the burner bar into the oven, and reinstall its mounting screws if you removed it.
Step 12 Test for proper igniter operation
Restore power and set the oven temperature to check that the igniter glows bright cherry red.
Treat a glowing igniter with no flame after about two minutes as a sign of a weak igniter or a gas valve problem.
Step 13 Test the oven safety valve for continuity
Locate the safety valve underneath the stove.
Identify the two sets of connections for broil and bake, which are typically color-coded.
Remove one spade connector from the wire harness on the valve.
Use a multimeter to measure across the valve terminals, and treat continuity or low ohms as good.
Step 14 Measure igniter amperage when it glows but won’t light
Set a multimeter with an amp clamp to the 20 amp mode.
Clamp the meter around a single igniter wire, and clamp it before restoring power if possible.
Restore power, set the oven to bake at 350 °F, and read the amperage draw.
Step 16 Reinstall the baffle and oven bottom panel
Hook the oven baffle into the two small slots at the back of the stove.
Channel the front of the baffle into the small ledge at the front of the oven cavity.
Slip the baffle down so it locks into the area where the thumb screws go, then reinstall the baffle screws.
Reinstall the main oven panel, and tighten the two thumb screws by hand.
Step 17 Reinstall the oven door and warming drawer
Slide the two hinge arms of the oven door into the chassis slots.
Pull the door down to open it, then push the door latches back into place so the hinges lock.
Reinstall the warming drawer, and slide it back to make sure it locks in place.
If the oven lights normally again after igniter replacement, confirm reliable bake operation through a full preheat before replacing any other gas components. If the igniter glows correctly and the safety valve still checks good, continue with thermostat and control diagnosis rather than swapping more ignition parts. Repair didn't go as planned? Ask our Answers community for help.
