Introduction
Use this guide to diagnose the common causes of a Hotpoint dryer that will not start, including a failed door switch, a broken belt path, or a start-circuit fault. Follow the checks in order to avoid unnecessary disassembly, and wear work gloves whenever you handle sharp cabinet panels.
Step 1 Inspect the timer knob and shaft
Turn the timer clockwise and listen for a strong clicking sound from the mechanism.
Pull the knob straight off and examine the plastic insert for cracks or stripping.
Check the exposed metal shaft for rounding or breakage that prevents rotation.
Step 2 Examine the push to start button
Use a flat-blade screwdriver to pry the plastic button from the console without twisting the clips.
Look for cracks, deformation, or missing plastic that could keep the plunger from reaching the switch.
Press directly on the exposed switch body to see whether the dryer starts with the button removed.
Step 3 Check motor start windings by hand-spin
Open the door and tape the door switch closed so the machine thinks the door is shut.
Rotate the drum counter-clockwise while pressing the start button.
Step 4 Determine if the dryer only runs when held
Hold the start button and see whether the motor stops as soon as the button is released.
Step 5 Inspect the incoming power connections
Slide the dryer forward, remove the single quarter-inch screw and drop the rear lower cover that guards the cord block.
Look for burnt, loose or broken wires on the terminal block and power cord ends.
Step 6 Verify supply voltage at the cord block
Set the multimeter to AC volts, keep the dryer plugged in and measure center to left then center to right posts; both should read about 120 V.
Measure across the two outer posts and confirm 208-240 V.
Step 7 Test the main thermal fuse
Unplug the dryer, set the meter to continuity and touch a lead to each terminal of the small fuse on the blower housing base.
Step 8 Remove the console back panel
Take out two quarter-inch screws on the plastic end caps and four more securing the steel rear console cover.
Step 9 Check the push to start switch electrically
Remove the green ground screw so the console can pivot upward and clear the top.
Put the meter on continuity, back-probe the top red and bottom brown wires and press the start button.
Step 10 Optional tests on timer contacts and resistor
With the schematic as reference, rotate the timer to a heat cycle and check continuity through the motor circuit terminals.
Step 11 Pop the top and confirm belt condition
Remove two Phillips screws from the rear corners of the top panel and two more inside the door opening.
Slide a flat blade under the front seam to release the spring clips and raise the lid slightly.
Step 12 Disconnect the top light harness if fitted
Support the raised lid and unplug the small lamp harness at the left hinge area, pressing the locking tab while separating.
Step 13 Remove the front panel and door assembly
Extract one quarter-inch screw from each front side flange and prepare to lift the entire door panel.
Pull the panel forward and upward to clear the three bottom fingers that support it.
Slide the plastic guard aside, squeeze the latch, unplug the switch harness, and set the door panel aside.
Step 14 Release belt tension at the idler pulley
Reach your right hand behind the blower housing, pull the idler arm to the right and hook its metal hub on the motor bracket tab.
Slip the drum belt off the motor pulley and idler wheel completely.
Step 15 Lift out the drum
Grab the loose belt, raise the drum slightly and pull it straight forward, keeping it inside the stamped side channels.
Guide the rear bearing out of its socket while avoiding snags on the belt or cabinet edges.
Step 16 Clean lint and inspect interior components
Vacuum loose lint from the motor, blower housing and cabinet floor to restore airflow and prevent future fuse trips.
Step 17 Test the drum outlet thermostat
Pull one blue wire from the two-terminal thermostat on the blower outlet and read resistance across the exposed spades.
Measure the small orange terminals and expect roughly 9 kΩ at room temperature.
Step 18 Check safety and high-limit fuses on the heater
Remove one lead from the small fuse on the heater housing and verify continuity at 0 Ω.
Repeat the test on the adjacent high-limit thermostat; OL indicates the part is blown.
Step 19 Evaluate the belt switch operation
Keep the meter on continuity, pull the idler arm until you hear a click and watch for 0 Ω on the meter.
Step 20 Remove and test the door switch
Press the hidden clip on the switch body, slide it toward the drum and withdraw the switch from the panel.
Using the schematic, verify continuity between the white and brown wires with the switch released for the light circuit.
Close the switch plunger and verify continuity now shifts to the brown and yellow wires that feed the motor circuit.
Step 21 Install the new door switch
Slide the replacement switch into the front panel until the side clip locks behind the metal skin.
Reconnect the three-wire harness firmly, ensuring the plastic guard snaps back over the connector.
Step 22 Reinstall the drum and belt
Pull the idler arm onto its motor mount tab to hold tension back while you work.
Seat the belt in the rear drum groove, lift the drum and slide the rear bearing into its socket at the back panel.
Loop the belt around the motor pulley, release the idler arm and verify the belt tracks in the center of both pulleys.
Step 23 Verify smooth drum rotation
Rotate the drum by hand several turns and confirm the belt rides smoothly and no scraping sounds are present.
Step 24 Reattach the front panel and door
Hang the panel on the three lower chassis fingers and pivot it toward the cabinet until flush.
Reconnect the door switch harness if you left it detached and tuck the plastic guard back in place.
Install the two quarter-inch screws through the side flanges to secure the panel.
Step 25 Close the top and test operation
Swing the lid down, press along the front edge until both spring clips snap into the chassis.
Plug the dryer in and press start to confirm that it starts and runs normally.
Step 26 Secure remaining screws and console
Drive the two long Phillips screws into the door opening to lock the top to the front bulkhead.
Insert the two matching screws at the rear corners of the lid.
Pivot the console down, align the six plastic fingers with their slots and tap forward to lock.
Reinstall the green ground screw and the four quarter-inch screws that hold the metal console cover.
Finish by replacing the two top console mounting screws.
Step 27 Final confirmation
Run the dryer through a full heat cycle and monitor for normal sound, drum rotation and temperature rise.
Once the failed switch, belt path, or control issue is corrected, reassemble the dryer fully and confirm it starts without hesitation. Repair didn't go as planned? Ask our Answers community for help.
