How to Troubleshoot a GE Front Load Washer Stopping Mid Cycle and Not Spinning
Video Guide
This guide was transcribed from a YouTube video.
    • Confirm the washer is powered on with no cycle selected and the dial not pressed.
    • Press and hold the start pause button about 10 seconds until the lights flash and the display brightens.
    • Press start pause repeatedly to scroll through stored error codes for diagnostic clues.
    Ask FixBot
    • Press start pause to exit error code mode and return to standby.
    • Press and hold start pause while rotating the control dial 180 degrees counterclockwise.
    • Release the button when the lights flash, then rotate the dial clockwise to mode 14.
    • Shut the door, check water and drain connections, and press start pause to initiate spin.
    • Observe if the drum spins only four to seven seconds, indicating a failing inverter motor assembly.
    Ask FixBot
    • Disconnect power to the washer to ensure safety.
    • Gather a 6-in-1 screwdriver, a digital multimeter, a 14 mm socket, a door boot spring tool, and needle nose pliers.
    • Tilt or secure the washer as needed to safely access internal components without tipping.
    Ask FixBot
    • Pull out the dispenser drawer fully and press the tab on its left side to remove it.
    • Locate five screws in the dispenser housing three on the left and two on the right, and remove them with a Phillips driver.
    • Lift the console interface up about 15 degrees and pull it forward to unlatch from the bulkhead.
    • Remove three screws behind the interface along the top edge of the washer lid.
    Ask FixBot
    • Slide the top panel toward you while lifting it up to release it from the washer.
    • Set the top panel aside to reveal internal components such as the accelerometer and harness.
    Ask FixBot
    • Locate the accelerometer near the top with a small wire harness attached.
    • Ensure the harness is firmly connected and shows no broken or loose wires.
    • Replace the accelerometer if error codes persist despite secure connections.
    Ask FixBot
    • Open the washer door and remove two Phillips screws securing the plastic face plate on the right side.
    • Remove two more screws securing the door lock and lift it out through the door opening.
    • Pry away the door seal retaining wire with a thin screwdriver and roll the gasket off the front lip.
    • Disconnect the door lock harness and inspect wires for damage or breaks.
    Ask FixBot
    • Tilt the washer back to remove three bottom screws holding the front panel, then return the washer upright.
    • Remove nine top screws from the front panel with two at the corners and seven pointing downward.
    • Slide the damper fan assembly rearward if equipped and decouple it from the bulkhead.
    • Lift and pull the bulkhead forward to free it from the machine, watching for harness wires on both sides.
    Ask FixBot
    • Examine both door lock harnesses for bent broken or snapped wires that could cause lock errors.
    • Use a 14 mm socket to remove four bolts from the lower concrete counterbalance weight.
    • Hold the weight securely when removing the final bolts to prevent sudden movement.
    • Pull the counterbalance weight off its pegs and set it aside for more access to the drain pump and inverter.
    Ask FixBot
    • Spin the drain pump impeller by hand and feel for three or four strong points of magnetic resistance.
    • Measure about 20 ohms across the pump terminals using a multimeter to confirm functionality.
    • Replace the pump if it shows no strong resistance or an open reading on the meter.
    Ask FixBot
    • Locate the inverter assembly on the lower portion of the machine behind a plastic cover.
    • Use a small screwdriver or pliers to release six tabs securing the inverter cover then lift it off.
    • Unplug four wire harnesses from the inverter board and free any cable ties or wire trunks.
    • Detach two side clips and remove four screws to release the board from the plastic housing.
    • Seat the new inverter board in the housing align screws and clips and reattach the wire harnesses.
    • Inspect wires for damage around cable ties or connectors before replacing the inverter cover.
    Ask FixBot
    • Guide the inverter board back onto the chassis and secure it with its mounting hardware.
    • Reinstall the counterbalance weight with four bolts while holding it in place.
    • Position the front bulkhead on its aligning pegs and secure with all top and bottom screws.
    • Reconnect the door lock and door gasket then seat the wire retaining spring around the gasket lip.
    • Place the top panel reinstall the three lid screws and fasten the console with five dispenser screws.
    • Restore power clear error codes in diagnostic mode and run a spin test to confirm the repair.
    Ask FixBot
Clear any stored codes and run a test cycle after repairing the failed component so you can confirm the washer completes spin without stopping mid-cycle. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
6,551 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 135
Past 30 Days: 423
All Time: 3,715
