Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓Use this guide to troubleshoot a Kenmore stove when the oven turns on but does not heat. Common causes include a partially tripped double-pole breaker, a bad power cord, missing 240 V power at the terminal block, a failed bake element, or a faulty control board. This guide covers breaker checks, live-voltage testing with a multimeter, and bake-element resistance testing.
Step 1 Confirm the oven does not heat
Set the oven to Bake, choose a temperature, and press Start.
Look for the display indicator showing that the bake element, assist element, and fan are being called on.
Wait 15 to 20 minutes and check whether the oven reaches about 350 °F.
Step 2 Reset the double-pole breaker
Find the double-pole breaker that controls the stove.
Turn the breaker fully off, then turn it back on.
Test the oven again and check whether it heats.
Step 4 Prepare to test terminal block voltage
Pull the stove out enough to reach the terminal block where the power cord connects to the back of the stove.
Leave the stove plugged in for this voltage test.
Set a multimeter to AC volts.
Step 5 Measure voltage at the terminal block
Touch one multimeter probe to each outside terminal on the terminal block.
Move one probe to the center terminal and touch the other probe to one outside terminal.
Repeat the 120 V test from the center terminal to the other outside terminal.
Step 6 Interpret the terminal block readings
Look for about 240 V across the two outside terminals and about 120 V from the center terminal to each outside terminal.
Continue to the bake-element test only if the terminal block has the proper voltage readings.
Step 7 Disconnect power for the resistance test
Unplug the stove before testing the bake element for resistance.
Remove the orange wire from one bake-element terminal.
Remove the yellow wire from the other bake-element terminal.
Step 8 Test the bake element resistance
Set the multimeter to ohms.
Touch one probe to each bake-element terminal.
If the voltage readings are wrong, troubleshoot the breaker, outlet, cord, or other upstream power supply parts before replacing stove components. Repair didn't go as planned? Ask our Answers community for help.
