Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓Use this guide to troubleshoot a Whirlpool electric stove or range that will not lock, will not start self-clean, will not unlock correctly, or shows an F5 error code. The door-lock system uses a lock motor, latch bar, front door switch, and micro switch to move and confirm the oven-door latch position. This guide was written around one Whirlpool electric-stove layout, so related ranges may place these parts differently.
Step 1 Prepare the stove safely
Turn off the stove and let the cooktop, oven, and door-lock area cool completely.
Remove only the access panel needed to reach the door-lock motor.
Step 2 Identify the door lock parts
Locate the door-lock motor near the latch linkage.
Locate the latch bar that runs from the motor to the latch mechanism at the front of the stove.
Locate the front door switch where the oven door presses against the stove frame.
Locate the micro switch on the door-lock motor cam assembly.
Step 3 Understand the lock cycle
Pressing Clean and Start begins the lock cycle for self-clean.
The door-lock motor turns the latch bar, and the bar slides the actuator over to hook the oven door.
The front door switch must show that the door is closed before the stove will lock.
The micro switch tells the control board when the latch has moved left or right, which corresponds to the locked and unlocked positions.
Step 4 Test the door lock motor voltage
With power disconnected, attach the voltmeter leads to the two terminals coming from the door-lock motor.
Set the voltmeter to AC volts.
Close the oven door so the door switch is pressed during the test.
Start a clean cycle by pressing Clean and Start.
Read the voltage at the door-lock motor.
Step 5 Interpret the motor voltage test
Cancel the clean cycle after the voltage reading.
The door-lock motor should run again and move the latch back to the unlocked position.
If the motor gets voltage but does not move the latch, inspect the lock motor, latch bar, and latch mechanism for failure or binding.
If no voltage reaches the motor, test the door switch and micro switch before focusing on the control-board relays or wiring.
Step 6 Check the door switch with the oven light
Press the door switch in by hand.
If the oven light goes out, the door switch is working and is probably not the lock problem.
If the switch is not pressed in, or if the switch is bad, the stove thinks the door is open and will not lock.
If the light stays on while the switch is pressed, inspect the switch, its actuator, and its wiring.
Step 7 Test the micro switch
Attach the meter leads to the two leads coming off the micro switch.
Set the meter to continuity or beep mode.
Use a flathead screwdriver to press the small button on the micro switch.
No beep while the button is pressed means the micro switch or its wiring needs further repair.
Step 8 Match the symptom to the failed area
Use the test results to match the F5 error code or self-clean lock failure to the failed area.
A failed door switch can prevent self-clean because the stove reads the door as open.
A failed micro switch can stop the control board from confirming the locked or unlocked latch position.
A failed lock motor or bound latch linkage can keep the actuator from hooking the door even when power reaches the motor.
No power at the lock motor points to the door-switch circuit, micro-switch circuit, wiring, or control-board relays.
Use the test results to repair or replace the component that failed, and run a lock and unlock check before using self-clean again. Repair didn't go as planned? Ask our Answers community for help.
