How to Tie a Tie: Four-in-Hand
  1. How to Tie a Tie: Four-in-Hand, Preparation: step 1, image 1 of 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Four-in-Hand: step 2, image 1 of 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: The narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Four-in-Hand, Tying: step 3, image 1 of 1
    • Take the active end and cross it over the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Four-in-Hand: step 4, image 1 of 1
    • Wrap active end under the narrow end, so that it now points to the right.
  5. How to Tie a Tie: Four-in-Hand: step 5, image 1 of 1
    • Wrap active end over the narrow end, so that it now points to the left.
    • Note: leave this wrap a little loose, as it will be used in step 7.
  6. How to Tie a Tie: Four-in-Hand: step 6, image 1 of 1
    • Pull the active end up through the neck loop, so that it now points up.
  7. How to Tie a Tie: Four-in-Hand: step 7, image 1 of 2 How to Tie a Tie: Four-in-Hand: step 7, image 2 of 2
    • Pull the active end down through the wrap you created in step 5 (see second picture).
  8. How to Tie a Tie: Four-in-Hand, Finishing: step 8, image 1 of 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  9. How to Tie a Tie: Four-in-Hand: step 9, image 1 of 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  10. How to Tie a Tie: Four-in-Hand: step 10, image 1 of 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Congratulations! You've successful tied the Four-in-Hand knot!
5 other people completed this guide.
Electric Warthogs
776 Reputation
3 Guides authored
The Electric Warthogs Member of The Electric Warthogs
Community
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 32
All Time: 1,600
