How to Splice Wires for Appliance Repairs
Video Guide
This guide was transcribed from a YouTube video.
    • Unplug the appliance or turn off the breaker before touching any wiring.
    • WARNING: Don’t work on energized wires, because shock, burns, or fire can result.
    • Let hot components cool, and keep wires away from sharp sheet metal edges.
    • Expose only the wiring you need, and keep track of wire colors and locations.
    • Use an end-to-end connector when you’re joining two wire ends into one continuous line.
    • Use a tap connector when you need to add a second wire onto an existing wire without cutting the main line.
    • Diagram: End-to-end join: wire A — [connector] — wire B.
    • Diagram: Tap join: main wire — [tap point] — branch wire.
    • Strip the ends of two wires, insert both stripped ends into a wire nut, and twist the cap until tight.
    • Use wire nuts when you have plenty of room and the connection won’t be easily tugged or bumped.
    • Caution: Wire nuts can be too bulky for appliance cavities, and they can pop off if the splice is stressed.
    • Insert one stripped wire end into one side of an inline butt splice, and crimp it with a crimping tool or very strong pliers.
    • Insert the other stripped wire end into the other side, and crimp it the same way.
    • Note: Butt splices are neat and inline, but they take practice to crimp correctly.
    • Caution: A bad crimp can pull apart easily, and the damaged connector usually can’t be reused.
    • Unscrew the connector, and separate it into its collars and the center post section.
    • Slide a collar onto the first wire, twist the exposed strands tightly, and push the wire into the center post as firmly as you can.
    • Screw the collar into the center post until snug to lock the first wire in place.
    • Repeat the process with the second wire on the other side of the connector.
    • Pull on both wires to confirm the splice doesn’t slide out under a normal tug.
    • Note: These connectors use screw collars, so you can make a solid inline connection without special tools.
    • Note: Match the connector size to the wire when possible, because different collar sizes exist.
    • Unscrew the Posi-Tap body to expose the U-channel and the pin section.
    • Set the main wire into the U-channel so the connector wraps around the wire jacket.
    • Screw the pin section down as tight as you can until it stops, so the pin pierces the wire’s insulation and contacts the conductor.
    • Note: This style lets you tap a line without disturbing the main wire run.
    • Remove the branch-wire collar, insert the stripped and tightly twisted branch wire into the post section, and slide the collar onto the wire.
    • Screw the collar into the post section until snug to lock the branch wire in place.
    • Repeat the same tap-and-attach process for the second conductor when you’re adding a two-wire component, such as a heater.
    • Note: You may only need to trim back insulation, and in some cases scissors can be used to do it.
    • Open the connector lid to expose the channel, and lay the main wire into place.
    • Snap the connector shut to hold the main wire, then insert the branch wire into either side of the connector.
    • Press the metal clip down until fully seated so it cuts into the insulation and makes the electrical connection.
    • Caution: You’ll usually need a tool like a multi-tool to press the metal clip down reliably.
    • Note: Some versions include sealant to reduce oxidation in moist areas.
    • Use Posi-style connectors when you want a strong splice without specialty crimp tools.
    • Use Scotchlok-style taps when you want an inline, sealed tap and you can press the clip down properly.
    • Use wire nuts when space allows, such as locations where bulk isn’t an issue.
    • Redo any connection that pulls apart easily, and make sure the wire strands are tightly twisted and fully captured before tightening.
    • Use a correctly sized collar or connector if the wire won’t seat well or the splice won’t tighten securely.
    • Route the wiring so it won’t rub on metal, and reassemble the appliance before restoring power.
A reliable splice is tight, inline when possible, and passes a firm tug test without slipping. If a splice looks bulky for the cavity or seems easy to pull apart, redo it before powering the appliance back on.
Ben Schlichter
6,526 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 71
All Time: 189
