How to Restore a Torn Nike Flip-Flop
  1. How to Restore a Torn Nike Flip-Flop, How to Restore a Torn Nike Flip-Flop: step 1, image 1 of 1
    • Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
  2. How to Restore a Torn Nike Flip-Flop: step 2, image 1 of 2 How to Restore a Torn Nike Flip-Flop: step 2, image 2 of 2
    • Clean off any additional residue with soap, water, and a towel or toothbrush.
    • Allow the flip-flop to air dry before moving on.
  3. How to Restore a Torn Nike Flip-Flop: step 3, image 1 of 1
    • Gently apply the adhesive on the torn parts of the flip-flop.
    • Make sure the torn parts are completely covered. Overspill is okay.
    • Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
    • Be sure to wear gloves and be in a ventilated environment when applying the adhesive.
  4. How to Restore a Torn Nike Flip-Flop: step 4, image 1 of 1
    • Once the adhesive is dry remove any extra adhesive that might have spilled over with the sandpaper.
  5. How to Restore a Torn Nike Flip-Flop: step 5, image 1 of 3 How to Restore a Torn Nike Flip-Flop: step 5, image 2 of 3 How to Restore a Torn Nike Flip-Flop: step 5, image 3 of 3
    • Take the needle and thread and begin to sew a cross stitch from the strap to the torn part of the flip-flop.
    • It may be easier to use an upholstery needle to get through the rubber material.
  6. How to Restore a Torn Nike Flip-Flop: step 6, image 1 of 1
    • Cover the stitched region with Plasti Dip.
    • Allow 4 hours to dry.
    • Make sure to apply the Plastic Dip in a proper environment with venalation or outside.
The Nike Flip-Flop(s) are now restored and can be worn again.
7 other people completed this guide.
Adrian Yearby
265 Reputation
1 Guide authored
2 Comments
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
masood daud - Reply
Oh darn I see it now.lol
masood daud - Reply
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 60
All Time: 15,556
