How to Replace the Rivets in a Clipboard
  1. How to Replace the Rivets in a Clipboard, Rivets in a Clipboard Clip: step 1, image 1 of 3 How to Replace the Rivets in a Clipboard, Rivets in a Clipboard Clip: step 1, image 2 of 3 How to Replace the Rivets in a Clipboard, Rivets in a Clipboard Clip: step 1, image 3 of 3
    • Use masking tape to secure the clipboard on a hard, flat surface.
  2. How to Replace the Rivets in a Clipboard: step 2, image 1 of 3 How to Replace the Rivets in a Clipboard: step 2, image 2 of 3 How to Replace the Rivets in a Clipboard: step 2, image 3 of 3
    • Wedge a screwdriver head under the rivets that need to be replaced.
    • Use a hammer to tap down on the handle of the screwdriver and pop the rivet heads upward and off the rivet backs.
    • Caution: Make sure to angle the hammer away from your fingers to avoid injury.
  3. How to Replace the Rivets in a Clipboard: step 3, image 1 of 2 How to Replace the Rivets in a Clipboard: step 3, image 2 of 2
    • If necessary, use pliers to remove tricky rivet heads.
  4. How to Replace the Rivets in a Clipboard: step 4, image 1 of 2 How to Replace the Rivets in a Clipboard: step 4, image 2 of 2
    • Remove the tape from the clipboard.
    • Pull the backs of the old rivets from the cutout holes in the clipboard.
    • Set aside the old rivet pieces and the detached metal clip.
  5. How to Replace the Rivets in a Clipboard: step 5, image 1 of 3 How to Replace the Rivets in a Clipboard: step 5, image 2 of 3 How to Replace the Rivets in a Clipboard: step 5, image 3 of 3
    • Place the metal clip on the board, aligning its cutout holes with those in the board.
    • Thread the new rivet backs through the cutout holes in the wooden board and those in the metal clip.
  6. How to Replace the Rivets in a Clipboard: step 6, image 1 of 1
    • Use masking tape to secure the clipboard on a flat surface.
  7. How to Replace the Rivets in a Clipboard: step 7, image 1 of 2 How to Replace the Rivets in a Clipboard: step 7, image 2 of 2
    • Align the new rivet heads with the rivet backs.
    • Gently push the rivet heads into the rivet backs to temporarily secure them in place.
  8. How to Replace the Rivets in a Clipboard: step 8, image 1 of 2 How to Replace the Rivets in a Clipboard: step 8, image 2 of 2
    • Place a marker or pad over the rivet heads to protect them and the clipboard while hammering.
    • Hammer the rivet heads into the rivet backs to secure the metal clip to the board.
    • Make sure to hold the cylindrical tool at a distance from the hammer to avoid injury.
  9. How to Replace the Rivets in a Clipboard: step 9, image 1 of 2 How to Replace the Rivets in a Clipboard: step 9, image 2 of 2
    • Remove the tape and check that the rivets have securely fastened the metal clip.
    • If the metal clip is still loose, repeat steps 6-8 until it sits securely against the board.
Finish Line
Alex Briggs
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 62
All Time: 468
