How to Replace the Key Fob Battery in a 2018 BMW 330i
  1. How to Replace the Key Fob Battery in a 2018 BMW 330i, Key Fob Battery: step 1, image 1 of 2 How to Replace the Key Fob Battery in a 2018 BMW 330i, Key Fob Battery: step 1, image 2 of 2
    • Press the small button on the back of the key fob to release the mechanical key.
    • Pull the key out completely.
  2. How to Replace the Key Fob Battery in a 2018 BMW 330i: step 2, image 1 of 1
    • Insert the mechanical key into the slot and gently twist it to pry open the key fob case.
    • Be careful not to use excessive force, as this may damage the plastic casing.
  3. How to Replace the Key Fob Battery in a 2018 BMW 330i: step 3, image 1 of 2 How to Replace the Key Fob Battery in a 2018 BMW 330i: step 3, image 2 of 2
    • Once the key fob is open, you will see the CR2450 battery inside. Make a note of its positive (+) and negative (-) orientation.
    • Carefully remove the old CR2450 battery by lifting it out with a nylon spudger or your fingernail.
    • Avoid using sharp metal tools to prevent damage to the battery compartment.
  4. How to Replace the Key Fob Battery in a 2018 BMW 330i: step 4, image 1 of 3 How to Replace the Key Fob Battery in a 2018 BMW 330i: step 4, image 2 of 3 How to Replace the Key Fob Battery in a 2018 BMW 330i: step 4, image 3 of 3
    • Place the new CR2450 battery in the correct orientation, with the positive (+) side facing up.
    • Ensure the battery is properly seated in the battery slot.
    • Double-check that the battery is positioned correctly before closing the key fob.
  5. How to Replace the Key Fob Battery in a 2018 BMW 330i: step 5, image 1 of 1
    • Align the two halves of the key fob and press them firmly together until you hear a click.
    • Ensure all edges are securely snapped back into place.
  6. How to Replace the Key Fob Battery in a 2018 BMW 330i: step 6, image 1 of 1
    • Slide the mechanical key back into the key fob until it locks into place.
    • Press the lock/unlock buttons to ensure the key fob is working.
    • If the key fob does not respond, recheck the battery installation to ensure it is properly seated.
Musab Abdelmagid
154 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 135
All Time: 891
