How to Replace the Bearings on a Street Skateboard
  1. How to Replace the Bearings on a Street Skateboard, Bearings: step 1, image 1 of 1
    • Lay the skateboard on its side so that bearings and axles are facing toward you.
    Ask FixBot
  2. How to Replace the Bearings on a Street Skateboard: step 2, image 1 of 3 How to Replace the Bearings on a Street Skateboard: step 2, image 2 of 3 How to Replace the Bearings on a Street Skateboard: step 2, image 3 of 3
    • Using a skateboard tool or wrench, unscrew the axle nut above the wheel.
    • Remove the wheel from the axle.
    Ask FixBot
  3. How to Replace the Bearings on a Street Skateboard: step 3, image 1 of 3 How to Replace the Bearings on a Street Skateboard: step 3, image 2 of 3 How to Replace the Bearings on a Street Skateboard: step 3, image 3 of 3
    • Position the wheel halfway on the end of the axle.
    • Holding the skateboard down with your other hand, use the end of the axle to pry the bearing out.
    Ask FixBot
  4. How to Replace the Bearings on a Street Skateboard: step 4, image 1 of 2 How to Replace the Bearings on a Street Skateboard: step 4, image 2 of 2
    • Set the old bearing aside.
    • Repeat the previous step with the other side of the wheel to remove the other bearing.
    Ask FixBot
  5. How to Replace the Bearings on a Street Skateboard: step 5, image 1 of 3 How to Replace the Bearings on a Street Skateboard: step 5, image 2 of 3 How to Replace the Bearings on a Street Skateboard: step 5, image 3 of 3
    • Place a fresh bearing face down (colored side down) onto the axle, and push the wheel down against the metal truck to pop the new bearing in.
    • Hold the skateboard in place with your other hand.
    Ask FixBot
  6. How to Replace the Bearings on a Street Skateboard: step 6, image 1 of 1
    • Take the wheel off.
    • Add another fresh bearing onto the axle.
    • Repeat the previous step for the other side of the wheel by pushing the wheel down to pop the bearing in.
    Ask FixBot
  7. How to Replace the Bearings on a Street Skateboard: step 7, image 1 of 3 How to Replace the Bearings on a Street Skateboard: step 7, image 2 of 3 How to Replace the Bearings on a Street Skateboard: step 7, image 3 of 3
    • Place washer(s) onto the axle and then screw the axle nut back on.
    Ask FixBot
    • Repeat steps as needed with other wheels.
    Ask FixBot
Finish Line
Maxen Hamelynck
157 Reputation
1 Guide authored
UC Davis, Team 1-4, Morris Winter 2025 Member of UC Davis, Team 1-4, Morris Winter 2025
UCD-MORRIS-W25S1G4
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 40
All Time: 223
