How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+
Views: 13K
View statistics:
Past 24 Hours:
21
Past 7 Days:
145
Past 30 Days:
624
All Time:
13,390
Comments: 10
4 comments on steps, 6 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the back cover adhesive and install the back cover on a Samsung Galaxy S22 or S22+.
The back cover has a three-piece design, with the adhesive layered between the camera bezel and metal cover.
Note: You only need to replace the adhesive if you're reusing the back cover. Back cover replacements should come with new adhesive pre-installed.
Parts
Tools
    1. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Heat the camera bezel: step 1, image 1 of 1
      • If you're replacing the back cover and it comes with adhesive pre-installed, skip to this step.
      • Apply a heated iOpener to the camera bezel on the back cover for two minutes.
      • You can also use a hair dryer or heat gun to heat the camera bezel.
      Ask FixBot
    2. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Separate the metal camera cover: step 2, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Separate the metal camera cover: step 2, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Separate the metal camera cover: step 2, image 3 of 3
      • Be careful not to bend or deform the metal camera cover during removal. If it's damaged, try to bend it back into shape or replace it to ensure a proper seal.
      • Insert an opening pick beneath the metal camera cover at its bottom edge.
      • The metal cover is strongly adhered. If you can't insert a pick, apply more heat to soften the adhesive.
      • Slide the pick around the cover's bottom‑left corner to separate it from the adhesive.
      Ask FixBot
    3. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 3, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 3, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 3, image 3 of 3
      • Re‑heat the metal camera cover.
      • Slide the opening pick around the entire perimeter of the metal camera cover to separate it from the adhesive.
      Ask FixBot
    4. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the metal camera cover: step 4, image 1 of 2 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the metal camera cover: step 4, image 2 of 2
      • Peel the metal cover off the back cover and remove it.
      Ask FixBot
    5. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the perimeter adhesive: step 5, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the perimeter adhesive: step 5, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the perimeter adhesive: step 5, image 3 of 3
      • Use blunt nose tweezers or your fingers to lift the thin adhesive strip off the perimeter of the back cover.
      • If it doesn't lift easily, apply heat to the perimeter.
      • Heat the adhesive on the camera bezel.
      Ask FixBot
    6. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the camera adhesive: step 6, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the camera adhesive: step 6, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the camera adhesive: step 6, image 3 of 3
      • During removal, the camera bezel will likely detach from the back glass.
      • Use your fingers to pull up the remaining adhesive from the camera bezel with slow, steady force.
      • This section of adhesive can be difficult to remove. Be careful not to bend or crack the back glass.
      Ask FixBot
    7. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the microphone adhesive: step 7, image 1 of 2 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the microphone adhesive: step 7, image 2 of 2
      Ask FixBot
    8. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Clean the remaining adhesive residue: step 8, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Clean the remaining adhesive residue: step 8, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Clean the remaining adhesive residue: step 8, image 3 of 3
      Tool used on this step:
      iFixit Adhesive Remover
      $19.99
      Buy
      • If the camera bezel is still attached to the back glass, it should separate while removing the adhesive residue. It's easier to clean them individually than together.
      • Apply a few drops of isopropyl alcohol or adhesive remover to the flat end of a spudger.
      • Use the spudger to scrape off any large chunks of adhesive residue from the camera bezel. Apply more solvent to the spudger to help dissolve the adhesive.
      • You only need to remove large adhesive chunks—the smaller pieces will be wiped off later.
      Ask FixBot
    9. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 9, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 9, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 9, image 3 of 3
      • Repeat this process to scrape off any large chunks of adhesive residue from the perimeter of the back glass.
      Ask FixBot
    10. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 10, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 10, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 10, image 3 of 3
      $19.99
      Buy
      • Apply several drops of isopropyl alcohol or adhesive remover to a microfiber or lint free cloth.
      • Alternatively, use our adhesive cleanup kit.
      • Clean the camera bezel and back glass until they're free of adhesive residue.
      Ask FixBot
    11. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Clean the frame: step 11, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Clean the frame: step 11, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Clean the frame: step 11, image 3 of 3
      • Repeat the cleaning process to remove any adhesive residue from the frame of the phone.
      Ask FixBot
    12. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Reinstall the camera bezel: step 12, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Reinstall the camera bezel: step 12, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Reinstall the camera bezel: step 12, image 3 of 3
      • Lay the back glass and camera bezel on a flat surface.
      • Align the camera bezel with the back glass, making sure the arrow is pointing toward the top of the cover.
      Ask FixBot
    13. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the new adhesive: step 13, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the new adhesive: step 13, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the new adhesive: step 13, image 3 of 3
      • Be very careful during this step! The back cover adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
      • Remove the clear plastic liner from the new back cover adhesive.
      • Grab the new adhesive by its pull tabs and align it over the back cover and camera bezel.
      • Place the adhesive on the back cover.
      • Use features such as the camera cutouts and perimeter notches to help align the adhesive.
      Ask FixBot
    14. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the liners: step 14, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the liners: step 14, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Remove the liners: step 14, image 3 of 3
      • Press firmly along the perimeter of the adhesive to adhere it.
      • Remove the main adhesive liner from the back cover using the pull tabs on the top and bottom edges.
      • If present, remove the secondary adhesive liner from the camera bezel using the pull tab on the bottom of the bezel.
      Ask FixBot
    15. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Prepare the metal cover: step 15, image 1 of 1
      • If you're replacing the metal camera cover, remove the main liner from the new cover using the black pull tabs.
      • If you're reusing the cover, ensure the cover is clean and wasn't deformed during removal. If it was, try bending it back into shape. If there's adhesive residue, apply solvent to a cloth and wipe it off.
      • If you clean the cover, be careful not to damage the gray foam or white vent.
      Ask FixBot
    16. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Install the metal camera cover: step 16, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Install the metal camera cover: step 16, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Install the metal camera cover: step 16, image 3 of 3
      • Orient the new metal camera cover so the white text is along the bottom of the camera bezel and the crosses are in the upper left and lower right corners.
      • Place the cover onto the camera bezel and apply pressure to adhere it.
      • If you're installing a new cover, remove the secondary liner using the white pull tabs.
      Ask FixBot
    17. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Replace the microphone adhesive: step 17, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Replace the microphone adhesive: step 17, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Replace the microphone adhesive: step 17, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • On the motherboard cover, remove the old adhesive from the microphone hole under the flash unit.
      • If you have replacement microphone adhesive:
      • Remove the clear liner from the large L‑shaped adhesive piece.
      • Place the square piece of adhesive over the back cover's microphone cutout under the flash unit, with the blue liner tab facing right.
      • Remove the blue liner.
      • If you don't have replacement microphone adhesive, use 1 mm strips of thin, double-sided tape instead. Apply the strips around the perimeter of the white microphone sticker on the back cover.
      Ask FixBot
    18. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the camera foam adhesive: step 18, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the camera foam adhesive: step 18, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the camera foam adhesive: step 18, image 3 of 3
      • If you're reusing the old metal camera cover, skip the next two steps.
      • If the replacement metal camera cover comes with foam preinstalled, skip this step.
      • Remove the clear liner from the camera foam adhesive.
      • Orient the adhesive over the camera cutouts with the circular section toward the top.
      • Place the adhesive onto the metal cover, making sure to use the markings around the camera cutouts to align it.
      • Remove the green liner from the adhesive.
      Ask FixBot
    19. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the air vent adhesive: step 19, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the air vent adhesive: step 19, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the air vent adhesive: step 19, image 3 of 3
      • If the replacement metal camera cover comes with the air vent preinstalled, skip this step.
      • Remove the clear liner from the air vent adhesive.
      • Place the adhesive onto the metal cover with the fuzzy side facing upward and the blue tab toward the bottom of the cover.
      • Use the markings on the cover to align the adhesive.
      • Remove the blue tab from under the adhesive.
      Ask FixBot
    20. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the metal camera cover corner adhesive: step 20, image 1 of 2 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Apply the metal camera cover corner adhesive: step 20, image 2 of 2
      • If you have a Galaxy S22+, there may be an additional piece of adhesive for the metal cover. If there isn't, skip this step.
      • The replacement adhesive we sell has this built in.
      • Remove the clear liner from the large two-piece adhesive sheet.
      • Align the adhesive over the notches in the bottom left of the metal cover.
      • Place the adhesive and apply pressure to adhere it.
      Ask FixBot
    21. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Install the back cover: step 21, image 1 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Install the back cover: step 21, image 2 of 3 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Install the back cover: step 21, image 3 of 3
      • Align the back cover with the frame and set it into place.
      • Press on the back cover to help the adhesive bond.
      Ask FixBot
    22. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Heat the back cover: step 22, image 1 of 2 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Heat the back cover: step 22, image 2 of 2
      • To help the adhesive bond, apply heat to all four edges of the back cover using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      Ask FixBot
    23. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Prepare the phone: step 23, image 1 of 2 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Prepare the phone: step 23, image 2 of 2
      • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of the phone. You can compensate for the camera bump by laying the phone face-down and placing coins around its perimeter.
      • Alternatively, you can use screen vise clamps around the perimeter of your device to set the new adhesive.
      • Place the phone screen-side-down on a soft, flat surface.
      • Apply blue painter's tape to the edges to protect its finish.
      • Stronger tape may peel off the paint from the frame of the phone. If you don't have blue painter's tape, use a paper towel or thin cloth instead.
      Ask FixBot
    24. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Press the adhesive: step 24, image 1 of 2 How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+, Press the adhesive: step 24, image 2 of 2
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back cover.
      • Stack them to a consistent height taller than the camera bump.
      Ask FixBot
    25. How to Replace the Back Cover Adhesive in a Samsung Galaxy S22 or S22+: step 25, image 1 of 1
      • Stack multiple books or other heavy objects on the coins.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
9 other people completed this guide.
Nick Schultz
67,786 Reputation
361 Guides authored
6 Guide Comments
Where do I get the adhesive
Isaac russell - Reply Share
Hi Isaac! This guide was written for the back cover adhesive included in the Samsung Fix Kits. Note that only the S22 and S22+ require this guide's procedure (the S22 Ultra has a different, yet much simpler, replacement procedure). If you only need the adhesive, check other online shops for the back cover adhesive replacement.
Clay Eickemeyer - Reply Share
I'm planning to get the adhesive from iFixit here, are microphone/camera foam/air vent adhesive a part of this part? Or do I need to try and find them somewhere else?
Stephen Jones - Reply Share
Hi Stephen! The exact part you linked to just comes with the sheet of display adhesive. This adhesive is for a repair we haven't written a guide for, but you can find a similar guide in the Galaxy S21 page. If you wish to use this guide to reassembly your S22 or S22+, you'll need the screen and battery kit. Or, if you only need the back cover adhesive to seal it up, this sheet of adhesive.
Feel free to reply here if you have any questions or if I didn't understand your question fully.
I just finished this. If I had to do it again I would definitely just get replacement back glass. Cleaning up all the old adhesive was such a PITA and very time consuming.
scrub - Reply Share
Past 24 Hours: 21
Past 7 Days: 145
Past 30 Days: 624
All Time: 13,390
