Introduction
In this guide, you will learn how to repair a frayed or damaged lightning cable by stripping the wire near the damaged area and using a soldering iron to ensure a solid connection.
Locate the damaged area of your lightning cable.
Use the 1.6 mm gauge on the wire strippers to strip a small portion of the outer jacket.
Peel the outer jacket from both sides of the damaged area, exposing the underlying metal jacket.
Carefully strip the metal jacket away from the underlying wires using the 1.0 mm gauge.
Use the scissors to cut the metal jacket off the cable.
Separate and examine the three main wires for any damage. Red (Power), White (Data), and Green (Data).
Separate the damaged wire from the other wires.
Strip the wire around the damaged area using the 0.6 mm gauge and expose the copper wires underneath.
Solder the exposed wires together, ensuring contact throughout the damaged area using the soldering iron.
Repeat for any other damaged wires.
Wrap the soldered part of the wire in a thin layer of electrical tape to insulate it from the other wires.
Repeat for all soldered wires.
