How to Repair a Jammed U-Lock Bike Lock
  1. How to Repair a Jammed U-Lock Bike Lock, How to Repair a Jammed U-Lock Bike Lock: step 1, image 1 of 2 How to Repair a Jammed U-Lock Bike Lock, How to Repair a Jammed U-Lock Bike Lock: step 1, image 2 of 2
    • Grab the lock and look inside the keyhole located under the lock.
  2. How to Repair a Jammed U-Lock Bike Lock: step 2, image 1 of 2 How to Repair a Jammed U-Lock Bike Lock: step 2, image 2 of 2
    • Grab the key to the lock and gently insert the key to test the resistance of the lock.
  3. How to Repair a Jammed U-Lock Bike Lock: step 3, image 1 of 3 How to Repair a Jammed U-Lock Bike Lock: step 3, image 2 of 3 How to Repair a Jammed U-Lock Bike Lock: step 3, image 3 of 3
    • Shake the WD-40 bottle side to side for 20 seconds, and flip the straw up for pinpoint stream.
  4. How to Repair a Jammed U-Lock Bike Lock: step 4, image 1 of 3 How to Repair a Jammed U-Lock Bike Lock: step 4, image 2 of 3 How to Repair a Jammed U-Lock Bike Lock: step 4, image 3 of 3
    • Spray a small amount of lubricant in the keyhole and the lock handle.
    • WARNING: Keep your eyes away from the lubricant, which can cause eye irritation.
    • Grab a cotton swab or a small brush to remove the dust from inside the keyhole and around the bottom of the handle.
  5. How to Repair a Jammed U-Lock Bike Lock: step 5, image 1 of 3 How to Repair a Jammed U-Lock Bike Lock: step 5, image 2 of 3 How to Repair a Jammed U-Lock Bike Lock: step 5, image 3 of 3
    • Insert the key into the keyhole and rotate it.
    • Use the key to move in and out the keyhole to loosen the internal pins.
    • Pull to open the shackle.
  6. How to Repair a Jammed U-Lock Bike Lock: step 6, image 1 of 3 How to Repair a Jammed U-Lock Bike Lock: step 6, image 2 of 3 How to Repair a Jammed U-Lock Bike Lock: step 6, image 3 of 3
    • Spray WD-40 into each hole of the lock.
    • Use a cotton swab to clean each hole.
  7. How to Repair a Jammed U-Lock Bike Lock: step 7, image 1 of 3 How to Repair a Jammed U-Lock Bike Lock: step 7, image 2 of 3 How to Repair a Jammed U-Lock Bike Lock: step 7, image 3 of 3
    • WARNING: Keep your eyes away from the lubricant spray.
    • Spray WD-40 on each end of the shackle.
    • Use a cotton swab to clean each end of the shackle.
  8. How to Repair a Jammed U-Lock Bike Lock: step 8, image 1 of 3 How to Repair a Jammed U-Lock Bike Lock: step 8, image 2 of 3 How to Repair a Jammed U-Lock Bike Lock: step 8, image 3 of 3
    • Insert the shackle into the lock.
    • Insert the key into the keyhole and turn it to lock the bike lock.
  9. How to Repair a Jammed U-Lock Bike Lock: step 9, image 1 of 2 How to Repair a Jammed U-Lock Bike Lock: step 9, image 2 of 2
    • Remove the key from the keyhole.
Finish Line
Tyler Kau
169 Reputation
1 Guide authored
UC Davis, Team 3-8, Serviss Fall 2025 Member of UC Davis, Team 3-8, Serviss Fall 2025
UCD-SERVISS-F25S3G8
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 129
