How to Repair a Eufy RoboVac 15C Max that Drives Erratically
  1. How to Repair a Eufy RoboVac 15C Max that Drives Erratically, How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 1, image 1 of 2 How to Repair a Eufy RoboVac 15C Max that Drives Erratically, How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 1, image 2 of 2
    • Remove the RoboVac from its charging station.
    • Flip it onto its back to expose the underside and wheels.
  2. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 2, image 1 of 2 How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 2, image 2 of 2
    • Grip the single swivel wheel and pull it directly upward.
    • The wheel and its mount should come free without needing much force.
  3. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the two 8.2 mm screws from both sides of the slot where the swivel wheel's axle was inserted.
  4. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 4, image 1 of 1
    • Lift the plastic axle plug from the rest of the RoboVac using the needle-nose pliers.
  5. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 5, image 1 of 1
    • Examine the small metal pin clinging to the plastic axle plug.
    • If the pin is bent out of shape or broken, the swivel wheel will not rotate properly, affecting the RoboVac's movement.
  6. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 6, image 1 of 1
    • Clear away any obstructions such as dirt or hair.
    • Adjust or replace the metal pin as necessary.
  7. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 7, image 1 of 1
    • Remove the two tri-brush attachments on the RoboVac's underside by prying them up and away from the RoboVac. This is necessary to keep the brushes out of the way.
  8. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 8, image 1 of 2 How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 8, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the eight 7.6 mm screws along the underside of the RoboVac's bumper.
  9. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 9, image 1 of 2 How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 9, image 2 of 2
    • Remove the two black plastic fasteners that were held in place by the screws.
  10. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 10, image 1 of 1
    • Remove the RoboVac's front bumper, which was held in place by the fasteners.
    • Avoid yanking the connecting cable between the RoboVac and the bumper.
  11. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 11, image 1 of 3 How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 11, image 2 of 3 How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 11, image 3 of 3
    • Unplug the connecting cable between the RoboVac and the bumper.
    • Do not pull the cords of the connecting cable; this can rip the cords from the white block. Use force on the white block instead.
    • Set the bumper aside.
  12. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 12, image 1 of 2 How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 12, image 2 of 2
    • Wipe the three black cliff sensors with a melamine sponge.
  13. How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 13, image 1 of 2 How to Repair a Eufy RoboVac 15C Max that Drives Erratically: step 13, image 2 of 2
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Use a microfiber cloth to clear away any debris.
    • Ensure that the bumper's two small lever arms spring back when pushed in.
    • Replace if necessary.
    • A jammed or broken bumper will cause the RoboVac to falsely believe there are obstructions ahead of it, causing it to drive erratically.
Your Eufy Robovac should be ready to go! Test the device by turning it on.
4 other people completed this guide.
One Comment
Is there any way to get a replacement metal clip that holds the swivel wheel in place? mine appears to have broken, and I'm out of warranty.
Patrick O'Brien - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 56
All Time: 2,739
