How to Repair a Daiso Earphone Case with a Torn Fabric Hinge
  1. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge, How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 1, image 1 of 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge, How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 1, image 2 of 2
    • Unzip the case and lay it flat.
    • Use scissors to cut off any unraveled fabric or stray threads.
  2. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 2, image 1 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 2, image 2 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 2, image 3 of 3
    • Push the end of the thread through the eye of the needle.
    • Wet the end of the thread to make it easier.
  3. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 3, image 1 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 3, image 2 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 3, image 3 of 3
    • Unravel the thread from the spool.
    • Double up the thread as you unravel. Continue unraveling until you have about 15-20 inches in total.
    • Pull out more thread than you need.
    • Cut the thread where the ends meet.
    • Adjust the folded thread until both sides are as equal as possible.
  4. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 4, image 1 of 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 4, image 2 of 2
    • Tie a knot about an inch from the end of the thread.
    • You may need to make more knots. Doing so will prevent the thread from slipping out of the fabric hinge in the steps ahead.
  5. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 5, image 1 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 5, image 2 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 5, image 3 of 3
    • Align the three layers exactly as they’d be if the layers were intact.
    • To maintain the alignment more precisely, use sewing pins.
    • Position the needle to estimate how the needle will enter. Before inserting, the needle should keep a centimeter distance from the edge of the damaged fabric hinge. After inserting, it should intercept the fabric that runs parallel to the zipper teeth.
    • Pull the needle through all three layers of the hinge until the end knot stops against the fabric.
    • Insert the needle slowly and keep your fingers away from the exit point.
  6. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 6, image 1 of 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 6, image 2 of 2
    • If the zipper is torn, tuck the zipper back where it belongs. Hold the three layers in place.
    • The end of the zipper is inside the spine.
    • Shift the needle down the spine, toward the center of the case, vertically aligned with your previous pass.
    • Make sure the needle will pass through all three layers of fabric.
    • Pass the needle through the layers of fabric until the thread is tight without bunching the fabric. This is your first stitch.
    • Be careful not to push the needle through the zipper teeth.
  7. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 7, image 1 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 7, image 2 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 7, image 3 of 3
    • Position the needle at the spot where you made the first pass. It's the first entry point (farther from the center of the spine).
    • Pull the needle through until the thread is tight.
    • You should now have a stitch on both sides.
  8. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 8, image 1 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 8, image 2 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 8, image 3 of 3
    • Move the needle perpendicular to the stitch you made, going towards the black fabric of the case.
    • Repeat steps 5-8, making rows of stitches until the fabric is secure.
    • About three rows of stitches are enough to secure the fabric, but you can make more for extra strength.
  9. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 9, image 1 of 2 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 9, image 2 of 2
    • The final stitches will look like this. There will be a row of singular stitches on both sides.
    • Make sure you pull the final stitch so that the thread that is interwoven into the spine is firm and snug.
    • Make a knot to secure the stitches. The knot should be as close to the exit point as possible.
    • Use your finger or the needle to keep the thread flat as you close and tighten the knot.
    • Make several knots the same way you may have done in step 4 so the stitches will not come undone.
  10. How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 11, image 1 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 11, image 2 of 3 How to Repair a Daiso Earphone Case with a Torn Fabric Hinge: step 11, image 3 of 3
    • Cut off the excess thread on both sides of the earphone case. You may leave a small amount if you'd like.
    • The final case should zip up with ease. The fabric hinge should be secure.
    • Gently pull the two sides away from each other to test the strength of the hinge.
Finish Line
Natalie Whitmer
205 Reputation
1 Guide authored
UC Davis, Team 3-3, Whithaus Spring 2025 Member of UC Davis, Team 3-3, Whithaus Spring 2025
UCD-WHITHAUS-S25S3G3
2 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 312
