How to Repair a Broken Lip Gloss Stopper
  1. How to Repair a Broken Lip Gloss Stopper, How to Repair a Broken Lip Gloss Stopper: step 1, image 1 of 2 How to Repair a Broken Lip Gloss Stopper, How to Repair a Broken Lip Gloss Stopper: step 1, image 2 of 2
    • Always clean your hands and work area before opening any cosmetic product to avoid contamination.
    • Open the lip gloss tube and set the wand aside on a flat surface covered with a paper towel.
    • With a dry cotton swab, clean the neck and stopper of the lip gloss.
    • If your lip gloss tube is swollen, leaking, or cracked, do not attempt this repair. Dispose of the product safely and avoid skin contact with any deteriorated formula.
  2. How to Repair a Broken Lip Gloss Stopper: step 2, image 1 of 2 How to Repair a Broken Lip Gloss Stopper: step 2, image 2 of 2
    • Use a pair of clean tweezers to gently grip the edge of the stopper.
    • Pull it straight out with steady pressure to release it from the tube.
  3. How to Repair a Broken Lip Gloss Stopper: step 3, image 1 of 2 How to Repair a Broken Lip Gloss Stopper: step 3, image 2 of 2
    • Use a paper towel and a cotton swab dampened with a small amount of isopropyl alcohol to gently clean off any buildup, dried gloss, or residue.
    • Let the stopper air dry completely before later reinserting it into the tube.
  4. How to Repair a Broken Lip Gloss Stopper: step 4, image 1 of 1
    • Look for damage to the stopper.
    • Use a toothpick with a small amount of super glue and apply it to the crack or damaged area.
    • Before replacing the stopper, make sure to allow the glue to dry.
  5. How to Repair a Broken Lip Gloss Stopper: step 5, image 1 of 2 How to Repair a Broken Lip Gloss Stopper: step 5, image 2 of 2
    • Align the clean, dry stopper with the opening of the tube. Use the tweezers to press it down gently and firmly into place.
    • Reinsert the wand into the tube and twist it closed. Open it again to test the stopper.
    • The wand should be met with gentle resistance and a normal amount of product coating the wand.
    • If the wand is too loose or too coated in gloss, the stopper may be too worn out to reuse. A replacement stopper will be needed.
Finish Line
Nelly Juarez
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 41
All Time: 296
