How to Repair Scratches in Laminate Finish Furniture
  1. How to Repair Scratches in Laminate Finish Furniture, How to Repair Scratches in Laminate Finish Furniture: step 1, image 1 of 1
    • Clean the scratched area with a damp cloth or paper towel to remove any dust or debris.
  2. How to Repair Scratches in Laminate Finish Furniture: step 2, image 1 of 1
    • Apply a small amount of wood filler to a putty knife.
    • The amount of wood filler needed may vary depending on severity of the scratches.
  3. How to Repair Scratches in Laminate Finish Furniture: step 3, image 1 of 1
    • Spread the wood filler over the scratches using the putty knife until they are sufficiently filled in.
    • The putty knife can be used to scrape away excess wood filler and smooth the surface.
  4. How to Repair Scratches in Laminate Finish Furniture: step 4, image 1 of 1
    • Wipe away any residual wood filler from the surface using a damp cloth or paper towel.
  5. How to Repair Scratches in Laminate Finish Furniture: step 5, image 1 of 1
    • Allow the wood filler to dry completely based on the package instructions before resuming use.
  6. How to Repair Scratches in Laminate Finish Furniture: step 6, image 1 of 1
    • Sand over the wood filler using fine-grit sandpaper if a smoother finish is desired.
  7. How to Repair Scratches in Laminate Finish Furniture: step 7, image 1 of 1
    • Paint over the wood filler, if desired, to color match the filler with the furniture.
    • Wood filler comes in a variety of colors so painting may not be necessary.
Finish Line
Shelby
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 134
All Time: 1,647
