Introduction
Over time and use, the bolts that hold chair legs in place can become loose, wearing out the hole that holds the bolts and making the chair wobbly and unstable. When this happens, it causes the bolts to lose their grip. Instead of throwing the chair away, this guide will show you how to fix the loose bolts using simple tools and a few easy steps. This repair will make your chair sturdy again and help it last for years to come!
Clear a flat and clean space to work in.
Carefully turn the chair over to gain access to the leg and the bolt holes that need reinforced.
By reinforcing the loose bolts with wooden dowels/toothpicks, the chair is now sturdy and safe to use again. This fix helps prevent further damage and makes sure the bolts stay tight for a long time.
