How to Repair Dent in a Ping Pong Ball
  1. How to Repair Dent in a Ping Pong Ball, How to Repair Dent in a Ping Pong Ball: step 1, image 1 of 3 How to Repair Dent in a Ping Pong Ball, How to Repair Dent in a Ping Pong Ball: step 1, image 2 of 3 How to Repair Dent in a Ping Pong Ball, How to Repair Dent in a Ping Pong Ball: step 1, image 3 of 3
    • Pour water into an electric kettle.
    • When the kettle has at least over half of its capacity full, close the kettle's lid.
    • If an electric kettle is not available, the hot water can also be provided by a stove or water heater.
  2. How to Repair Dent in a Ping Pong Ball: step 2, image 1 of 3 How to Repair Dent in a Ping Pong Ball: step 2, image 2 of 3 How to Repair Dent in a Ping Pong Ball: step 2, image 3 of 3
    • Plug in the electric kettle.
    • Flip the switch on the kettle to turn it on, indicated by the light coming from the heating pad.
    • Wait approximately 2-3 minutes for the water to fully boil, before the kettle turns itself off.
    • Open the kettle's lid to make sure the water is boiling.
  3. How to Repair Dent in a Ping Pong Ball: step 3, image 1 of 3 How to Repair Dent in a Ping Pong Ball: step 3, image 2 of 3 How to Repair Dent in a Ping Pong Ball: step 3, image 3 of 3
    • Pour the hot water from the kettle into a clear container until the water level is high enough to submerge a dented ping pong ball.
    • Set the kettle aside, and unplug the heating pad.
  4. How to Repair Dent in a Ping Pong Ball: step 4, image 1 of 2 How to Repair Dent in a Ping Pong Ball: step 4, image 2 of 2
    • Place the dented ping pong ball onto the spoon with the dented side facing up.
  5. How to Repair Dent in a Ping Pong Ball: step 5, image 1 of 2 How to Repair Dent in a Ping Pong Ball: step 5, image 2 of 2
    • Submerge the dented ping pong ball into the hot water with the spoon.
    • Ensure that the dented side is always facing down to allow the hot water to buffer out the dent.
  6. How to Repair Dent in a Ping Pong Ball: step 6, image 1 of 2 How to Repair Dent in a Ping Pong Ball: step 6, image 2 of 2
    • Continue keeping the ping pong ball in the hot water with the spoon for several more minutes.
    • Inspect all angles of the ping pong ball to make sure there are no longer any visible dents.
    • If there are no longer any dents, scoop the ping pong ball out of the water using the spoon.
  7. How to Repair Dent in a Ping Pong Ball: step 7, image 1 of 2 How to Repair Dent in a Ping Pong Ball: step 7, image 2 of 2
    • Use the spoon to place the ping pong ball onto either a towel, napkin, or paper towel.
    • Dry off the ping pong ball, and let cool.
    • Test and see if the ping pong ball can bounce better after regaining its spherical shape.
    • Enjoy a game of ping pong with your friends! :)
The repair process is relatively simple to replicate, easy to follow, and above all, has a wide variety of options and alternatives if the required materials for fixing the ping pong ball are not available for use.
Richard Dong
172 Reputation
1 Guide authored
UC Davis, Team 1-10, Serviss Fall 2025 Member of UC Davis, Team 1-10, Serviss Fall 2025
UCD-SERVISS-F25S1G10
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 32
All Time: 200
