Introduction
Stripped screws are a nightmare to any repair enthusiast. Try as you might, some screws just do not want to come out. Frustration takes over and before you know it, that once "+" shape has turned into a "O". Never fear; we've got your back. This guide will walk you through how to use a rotary tool to remove a stripped screw by cutting a small slit in the screw head, allowing you to remove the screw with a flathead screwdriver.
Techniques:
Always wear safety goggles when using a rotary tool to prevent injury from debris or sparks.
Video Overview
Your screw is stripped, and your screwdriver is no longer sufficient. Before busting out the heavy hitters, try the following:
Use different screwdrivers. First try slightly smaller or larger head sizes, then a flat head screwdriver, to see if you can get it to catch on some part of the stripped screw.
If either of these techniques are fruitful, congrats! Your screw is free.
Stretch a rubber band over the stripped screw.
Insert a properly-sized screwdriver, and give it a turn.
Tool used on this step:Screw Extracting Pliers$19.99
If the screw head is accessible, try a pair of screw extracting pliers. If you can get a good grip, turn the pliers and the screw should turn along with it!
Once the screw is loosened a bit, you can probably back it out the rest of the way using a screwdriver.
Still stuck? Try adding a dab of superglue to the top of the screw.
Set your driver into the screw head, and allow the glue to dry.
Using a firm grip and downward pressure, give the driver a twist to remove the screw.
Attach a thin cutting disk to your rotary tool. Before you cut anything, make sure the disk is secured well.
Use a flathead screwdriver to remove the screw from the device.
The size of the driver will depend on the size of the screw, but use the largest size that will fit in your cut.
