How to Reattach a North Face Backpack Bungee Cord
  1. How to Reattach a North Face Backpack Bungee Cord, How to Reattach a North Face Backpack Bungee Cord: step 1, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord, How to Reattach a North Face Backpack Bungee Cord: step 1, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord, How to Reattach a North Face Backpack Bungee Cord: step 1, image 3 of 3
    • Find the North Face Backpack's broken Cord.
    • Use scissors to cut about an inch (24.5 mm) off the end of the broken bungee cord.
    • If there is more than an inch of fraying or damage to the cord, cut all of the frayed cord off. This makes it easier to pull the cord through the slit made in the next step.
    • Twist the end to make it easier to insert the cord back through the hole.
  2. How to Reattach a North Face Backpack Bungee Cord: step 2, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord: step 2, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord: step 2, image 3 of 3
    • Find the grommet where the cord should be reattached on the outside layer of the backpack.
    • Unzip the front pocket of the backpack and fold it back.
  3. How to Reattach a North Face Backpack Bungee Cord: step 3, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord: step 3, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord: step 3, image 3 of 3
    • Use scissors to cut a straight line in the inner fabric layer behind the grommet to allow the cord to pass through.
    • Try to keep the cut around 2–3 inches long—just wide enough to pull the cord through and access the grommet, while limiting the amount of sewing required in later steps.
    • Scissors can cut you, so be careful!
  4. How to Reattach a North Face Backpack Bungee Cord: step 4, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord: step 4, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord: step 4, image 3 of 3
    • Put the cord through the hole on the outside.
    • Pull the cord through the inside pocket.
  5. How to Reattach a North Face Backpack Bungee Cord: step 5, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord: step 5, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord: step 5, image 3 of 3
    • Tie a knot to prevent the cord from falling through.
    • Tie a second knot, making it a double knot to further secure the end of the cord.
    • Try to get the knot tied at the end of the cord so there is less leftover cord hanging off.
  6. How to Reattach a North Face Backpack Bungee Cord: step 6, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord: step 6, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord: step 6, image 3 of 3
    • Prepare a needle and thread with a double strand.
    • Pull the thread through the hole so it is an equal length on either side of the needle.
    • Cut the thread with enough length to sew up the 2-3 inch opening that was previously cut.
    • Make the thread a little longer than double the length of the opening, so you do not run out while sewing.
    • Tie the ends of the thread in a double knot.
    • Needles are sharp, so be careful. You can use the thimble to protect yourself by putting it on your thumb.
  7. How to Reattach a North Face Backpack Bungee Cord: step 7, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord: step 7, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord: step 7, image 3 of 3
    • Sew the fabric layer back together using a mattress stitch.
    • To do this, insert the needle horizontally across the two layers of fabric and pull the thread through to stitch them together.
    • Repeat the steps moving across the opening in the fabric.
  8. How to Reattach a North Face Backpack Bungee Cord: step 8, image 1 of 2 How to Reattach a North Face Backpack Bungee Cord: step 8, image 2 of 2
    • Fold the fabric over the first round of stitches.
    • Complete another pass of mattress stitch to cover the seam and make it more secure.
    • You might want someone to help you hold the folded fabric while you finish up stitching.
  9. How to Reattach a North Face Backpack Bungee Cord: step 9, image 1 of 3 How to Reattach a North Face Backpack Bungee Cord: step 9, image 2 of 3 How to Reattach a North Face Backpack Bungee Cord: step 9, image 3 of 3
    • Make a knot with the string to finish off the stitching.
    • After knotting, use the scissors to cut the string to close it off.
  10. How to Reattach a North Face Backpack Bungee Cord: step 10, image 1 of 2 How to Reattach a North Face Backpack Bungee Cord: step 10, image 2 of 2
    • Check your work by tugging on the cord from the outside.
Finish Line
Hannah Swope
181 Reputation
1 Guide authored
UC Davis, Team 3-1, Whithaus Spring 2025 Member of UC Davis, Team 3-1, Whithaus Spring 2025
UCD-WHITHAUS-S25S3G1
4 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 76
Past 30 Days: 298
All Time: 2,412
