How to Maintain an Envy Prodigy Headset
  1. How to Maintain an Envy Prodigy Headset, How to Maintain an Envy Prodigy Headset: step 1, image 1 of 3 How to Maintain an Envy Prodigy Headset, How to Maintain an Envy Prodigy Headset: step 1, image 2 of 3 How to Maintain an Envy Prodigy Headset, How to Maintain an Envy Prodigy Headset: step 1, image 3 of 3
    • Use a 6 mm Allen wrench to loosen the clamp screws
    • Do not remove the bolts—loosening them slightly is enough to free the bars.
    • Lift the handlebars straight up and off the fork.
    • If the bars are stuck, gently wiggle or tap them until they release.
    • It may take some force to remove the bars. Keep at them until they come off.
  2. How to Maintain an Envy Prodigy Headset: step 2, image 1 of 3 How to Maintain an Envy Prodigy Headset: step 2, image 2 of 3 How to Maintain an Envy Prodigy Headset: step 2, image 3 of 3
    • Hold the fork steady to prevent it from spinning.
    • Use the 5 mm Allen wrench to remove the top compression bolt on the top of the fork.
    • Carefully slide the fork down and out of the deck.
  3. How to Maintain an Envy Prodigy Headset: step 3, image 1 of 3 How to Maintain an Envy Prodigy Headset: step 3, image 2 of 3 How to Maintain an Envy Prodigy Headset: step 3, image 3 of 3
    • Remove the bearings from the deck tube.
    • Inspect each bearing for signs of rust or damage.
    • Wipe down both the deck tube and the bearings to remove dirt or moisture.
    • Apply a thin, even layer of bearing lubricant to the headset cups, bearing surfaces, and steerer tube before reassembly to reduce friction and prevent corrosion.
    • Reinsert the bearings into the deck tube.
    • They will snap back in place the same way they were removed.
  4. How to Maintain an Envy Prodigy Headset: step 4, image 1 of 3 How to Maintain an Envy Prodigy Headset: step 4, image 2 of 3 How to Maintain an Envy Prodigy Headset: step 4, image 3 of 3
    • Slide the fork back into the deck tube.
    • Insert the top compression bolt and hand-tighten it as far as possible.
    • Once it can no longer be turned by hand, use a 5 mm Allen wrench to tighten the bolt until it is snug.
    • If possible, give the bolt an extra quarter turn for a secure fit.
    • Over-tightening can lead to damaged bearings. Be careful while tightening.
  5. How to Maintain an Envy Prodigy Headset: step 5, image 1 of 2 How to Maintain an Envy Prodigy Headset: step 5, image 2 of 2
    • Slide the handlebars back onto the fork.
    • Align the clamp and begin tightening the bolts gradually.
    • Alternate between the bolts as you tighten to ensure even pressure and prevent damaging the clamp.
    • Once all bolts are snug, check that the handlebars are secure and properly aligned before riding.
    • Tightening only one side of the clamp at a time could break your clamp. Be sure to alternate bolts while tightening.
If everything is tightened correctly, your handlebars should spin freely but also feel solid.
Skyler Rains
171 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 162
