How to Install a Front Load Washer Door Boot Seal Using a Homemade Tool
Video Guide
This guide was transcribed from a YouTube video.
    • Unplug the washer before working around the door opening.
    • Turn off the water supply valves if you’ll be moving hands near hoses or the dispenser area.
    • Wear gloves and keep your face and fingers out of the spring’s path because the clamp can snap back and pinch you.
    • This method is most helpful for the outer, smaller spring clamp, but it can also be used on the inner spring clamp if needed.
    • Get a standard wrench that gives you enough leverage and width for the clamp, such as a 5/8-inch wrench or slightly larger.
    • Get two heavy-duty cable ties that are wide and strong, but still fit through the clamp’s eyelets.
    • Get needle-nose pliers to tighten the ties and help press the clamp into place.
    • Get side cutters, scissors, or another sharp cutter to remove the ties after the clamp is installed.
    • Optionally wrap masking tape around the tips of the pliers or a screwdriver to reduce the chance of nicking the rubber boot or scraping the washer’s metal.
    • Thread a cable tie through the box end (socket end) of the wrench.
    • Thread that cable tie through one eyelet of the door boot spring clamp.
    • Loosely latch the cable tie so the wrench and spring eyelet stay connected but can still shift.
    • Keep the spring mostly on one side of the wrench for the entire setup so it doesn’t twist into an unworkable position.
    • Diagram: [eyelet]—(tie)—[wrench box end], with the spring sitting to one side of the wrench instead of centered across it.
    • Thread the second cable tie through the other eyelet of the spring clamp.
    • Loosely latch that tie around the open end (mouth) of the wrench on the opposite side.
    • Work both ties tighter to begin spreading the spring clamp while keeping the spring mostly on the same side of the wrench.
    • Hand-tighten as far as you can, then use needle-nose pliers to pull the ties tighter for more leverage.
    • Caution: If a cable tie fails under tension, the spring can snap back and pinch you.
    • Grab the flat tail of the tie on the wrench mouth side with needle-nose pliers.
    • Use the tip of the wrench as a pivot point and lever the pliers to ratchet the tie tighter and spread the spring wider.
    • Repeat the same leverage method on the box end side if needed, but expect it to be a bit more difficult than the mouth side.
    • Stop tightening once the spring clamp is spread wide enough to attempt installation without forcing the boot out of its groove.
    • Diagram: [eyelet]—(tie)—[wrench box end] <——spring spread——> [wrench open end]—(tie)—[eyelet].
    • Press the door boot seal fully onto the washer’s front lip so it sits snug and even all the way around.
    • Lay the wire clamp around the boot seal and seat it into the same groove it came out of.
    • Aim the spring and wrench inward toward the washer housing as you work the clamp into the groove.
    • Work around the boot until you reach the area where the spring was originally positioned, which is often near the bottom and sometimes slightly offset depending on the brand.
    • At the spring area, press the wire and spring into the groove by hand to start it.
    • Use needle-nose pliers to press against the boot seal and push the spring and wrench inward until the clamp drops into the groove.
    • Press lightly and work from the outside of the spring toward the inside so you don’t slip and damage the rubber.
    • Optionally use a taped screwdriver tip to help press the wire and spring into place if pliers can’t reach comfortably.
    • If the clamp doesn’t pop in, press directly on the spring with the pliers or pivot the pliers toward the drum to help it seat.
    • Hold the wrench and spring steady so the clamp stays seated in the groove.
    • Cut both cable ties.
    • Use needle-nose pliers to pull the cut ties out of the wire clamp and away from the boot.
Check that the boot seal is fully seated on the washer’s front lip and that the wire clamp sits in the groove all the way around, especially near the spring. If the clamp won’t seat, the most common fixes are tightening the ties to spread the spring more, re-centering the boot so it isn’t riding out of the groove, and keeping the spring mostly on one side of the wrench so it doesn’t twist. If the pliers or a screwdriver could scratch the rubber or the cabinet, add masking tape to the tool tip and press lightly. Spring location and access vary by brand and model, so place the spring where it was originally installed (often near the bottom, sometimes offset) and work the clamp into the groove as you go.
Ben Schlichter
6,539 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 130
All Time: 382
