How to Fix a Wobbling Living Room Table
  1. How to Fix a Wobbling Living Room Table, How to Fix a Wobbling Living Room Table: step 1, image 1 of 2 How to Fix a Wobbling Living Room Table, How to Fix a Wobbling Living Room Table: step 1, image 2 of 2
    • Flip the table over and place it on top of the shelf.
  2. How to Fix a Wobbling Living Room Table: step 2, image 1 of 2 How to Fix a Wobbling Living Room Table: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the screws from the table leg.
    • Twist the screwdriver to the left (counterclockwise) to loosen the screw.
  3. How to Fix a Wobbling Living Room Table: step 3, image 1 of 2 How to Fix a Wobbling Living Room Table: step 3, image 2 of 2
    • Remove the cap from the wood glue.
    • Use scissors to cut open the tip so the glue is able to be squeezed out.
  4. How to Fix a Wobbling Living Room Table: step 4, image 1 of 2 How to Fix a Wobbling Living Room Table: step 4, image 2 of 2
    • Gently squeeze the wood glue into the screw holes.
  5. How to Fix a Wobbling Living Room Table: step 5, image 1 of 1
    • Carefully place the leg back into its original position.
  6. How to Fix a Wobbling Living Room Table: step 6, image 1 of 2 How to Fix a Wobbling Living Room Table: step 6, image 2 of 2
    • Put all the screws back into their original holes. Then use the Phillips #2 screwdriver to tighten each screw.
    • For the back section, use a drill if the screw won't go in with the screwdriver.
  7. How to Fix a Wobbling Living Room Table: step 7, image 1 of 3 How to Fix a Wobbling Living Room Table: step 7, image 2 of 3 How to Fix a Wobbling Living Room Table: step 7, image 3 of 3
    • Place the table in a safe location and let it sit for at least 30 minutes.
    • After the time has passed, flip the table back onto its legs and gently shake it to make sure the glue has set.
Once you have finished this guide, your table should no longer be slanted.
Taurus Black
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 81
All Time: 444
