Introduction
Have a broken necklace still lying around because you can't bear to get rid of it? This simple guide to repairing the chain will make it wearable again in no time.
Test the closure by gently pulling it from either side. If it comes apart repeat steps 4 and 5.
Omg! Thank you. Literally I was so sad that my necklace broke cos it was of my favourite band. Thank you
Jewelers newer use the needle nose pliers to fix the chain. Unless to put the needle thru the chain link and push inside to open that chain link. They use any different but not needle nose- to squeeze the links back. Best way- to twist the link by two pliers ( not needle nose!!) put thru the chain link and twist it back.
Now you're ready to flaunt your old necklace once again!
35 other people completed this guide.
12 Comments
My chain broke when my 7 year old cousin pulled on it when he was piggy back ridding me. Ha Ha. Only took 20 min to do this. Very easy bit best to have nimble and dexterous fingers
With the smaller necklaces, the broken link always falls off really easily, is there a way to make that easier to fix?
My costly gold chain break down...as it is very lin... How can I joint it
I would like to say that my gold chain down due to its thinness...how can I joint this chain
A link broke in my dogs chain collar. I'm using needle nose pliers, but I can't get the two ends of the open link to line up so I can close it!! I've never had this problem before!
This is so hard to do. I can’t even put the links together.
I acsadently broke my necklace
Jayden ayala
I want to say that my gold ring is down due to its thinness... Can you tell me how I can attach this chain?
