How to Fix a Broken Air-Dry Clay Figurine
  1. How to Fix a Broken Air-Dry Clay Figurine, How to Fix a Broken Air-Dry Clay Figurine: step 1, image 1 of 1
    • Collect the air-dry clay fractures.
  2. How to Fix a Broken Air-Dry Clay Figurine: step 2, image 1 of 1
    • Brush out the clay debris from the clay piece's surface.
  3. How to Fix a Broken Air-Dry Clay Figurine: step 3, image 1 of 2 How to Fix a Broken Air-Dry Clay Figurine: step 3, image 2 of 2
    • Preheat the hot glue gun.
    • Apply the hot glue onto the cracked surface.
    • Try to work quickly on this step. The hot glue dries and hardens very fast.
  4. How to Fix a Broken Air-Dry Clay Figurine: step 4, image 1 of 1
    • Attach the corresponding fractured pieces. Press and hold the clay for at least 10 seconds to allow the clay to set.
    • Strip away excess hot glue to avoid potential additional damage.
    • If there are multiple cracks, repair one fractured area at a time to prevent hassle.
  5. How to Fix a Broken Air-Dry Clay Figurine: step 5, image 1 of 2 How to Fix a Broken Air-Dry Clay Figurine: step 5, image 2 of 2
    • Place a small amount of air-dry clay on the paint palette.
    • Apply some water to the air-dry clay and mix them with a brush or your fingers.
    • Add water gradually to avoid over-moisturizing the paste.
    • Continue mixing until the paste reaches a jam-like consistency.
  6. How to Fix a Broken Air-Dry Clay Figurine: step 6, image 1 of 3 How to Fix a Broken Air-Dry Clay Figurine: step 6, image 2 of 3 How to Fix a Broken Air-Dry Clay Figurine: step 6, image 3 of 3
    • Grab some clay paste and apply it along the cracked surface.
    • Smooth out the paste with your fingers or a brush.
  7. How to Fix a Broken Air-Dry Clay Figurine: step 7, image 1 of 1
    • Choose one of the following steps that fits the best:
    • Wait for the air-dry clay to fully dry and harden. This step takes at least 2 days.
    • Use a blow dryer to speed up the drying process. This step is optional, but the dry time can be shortened to 15 minutes.
    • Rushing to the next step without allowing the ornament to fully dry may result in additional damages.
  8. How to Fix a Broken Air-Dry Clay Figurine: step 8, image 1 of 1
    • Polish the repaired surface using sandpaper.
  9. How to Fix a Broken Air-Dry Clay Figurine: step 9, image 1 of 2 How to Fix a Broken Air-Dry Clay Figurine: step 9, image 2 of 2
    • Paint the dried clay with the corresponding colors.
  10. How to Fix a Broken Air-Dry Clay Figurine: step 10, image 1 of 2 How to Fix a Broken Air-Dry Clay Figurine: step 10, image 2 of 2
    • Paint the repaired surface with glossy or matte varnish.
    • Wait for the varnish to be fully dried. This takes 1 day.
    • Do not use a blow dryer for this step. Varnish cannot be dried through hot air.
  11. How to Fix a Broken Air-Dry Clay Figurine: step 11, image 1 of 2 How to Fix a Broken Air-Dry Clay Figurine: step 11, image 2 of 2
    • The broken air-dry clay craft ornament is now fixed!
Finish Line
2 other people completed this guide.
Rhea Matsumoto
245 Reputation
1 Guide authored
UC Davis, Team 3-5, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 3-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G5
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 105
All Time: 1,166
