How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook
  1. How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook, How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 1, image 1 of 2 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook, How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 1, image 2 of 2
    • Use pliers to reshape the bent coil into a rounded ring shape, as close as possible to its original state.
    • The reshaped coil does not have to be in a perfect circular shape, just round enough so the coil can be twisted off the notebook later.
  2. How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 2, image 1 of 3 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 2, image 2 of 3 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 2, image 3 of 3
    • Given that both ends of the coil are clasped, unravel one of those ends with pliers or by hand, twisting until loose and detached from the end rings so that the coil can be twisted off the notebook later.
    • Spiral coils can be sharp on both ends so remove the spiral coil with extra care.
  3. How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 3, image 1 of 3 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 3, image 2 of 3 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 3, image 3 of 3
    • Twist the coil until the coil has been removed from the notebook.
  4. How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 4, image 1 of 1
    • Repair any torn holes on the notebook cover with reinforcement stickers.
  5. How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 5, image 1 of 2 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 5, image 2 of 2
    • Starting with one of the coil's ends, insert it through a hole on either end of the notebook and twist the coil back into the notebook.
    • Continue threading the coil through each hole, moving up until the last hole at the top.
  6. How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 6, image 1 of 3 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 6, image 2 of 3 How to Fix a Bent Spiral Coil & Reinforce Torn Holes on a Notebook: step 6, image 3 of 3
    • After the coil is put back into place, loop both ends of the coil around the last spiral of both ends. Use the pliers to clasp the just-formed loops together to secure it.
Finish Line
Pachia Yang
148 Reputation
1 Guide authored
UC Davis, Team 4-1, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 4-1, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G1
4 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 99
All Time: 947
