Introduction
Repair snagged jeans with simple skills, such as threading a needle or tying a knot. Repairing the snagged denim will prevent further tearing, and will make the denim more visually appealing.
Insert the sharp end of your ballpoint needle through the center of the snag.
Carefully turn the jeans inside out, while maintaining the placement of the ballpoint needle.
Allow the ballpoint needle to stand vertically. This will happen naturally.
Take your No. 18 tapestry needle and gently maneuver all of the loose strings from the snagged denim to the inside of the jeans. You will position your needle to pull the loose strings upward.
Once you've removed the excess thread, take a small amount of fabric adhesive, and rub it against the knot you made to confident the snagged denim. The adhesive will secure the loose strings inside the denim.
Apply the adhesive so that the knot is stuck to the surface of the denim.
