Introduction
Wire leads are attached inside to heat the toaster oven. Use this guide to repair the heating mechanism to regain use of your toaster oven.
Parts
No parts required.
  1. If one of the heating mechanisms isn’t working, make sure all wire leads are attached inside the toaster oven.
    • If one of the heating mechanisms isn’t working, make sure all wire leads are attached inside the toaster oven.
      • When a broken lead is found, reattach by removing the screw at its original attachment point.
  2. Spread Fixmas Cheer
    Get $12 off your purchase of $50 or more with code FIXMAS12
    Spread Fixmas Cheer
  3. Make sure that the lead is attached and in contact.
    • Make sure that the lead is attached and in contact.
    • Retighten screw to secure lead.
Tony Wang
64 Reputation
5 Guides authored
Cal Poly, Team 6-35, Regan Fall 2012 Member of Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 974
