How to Drill a Keyring Hole in an AirTag
  1. How to Drill a Keyring Hole in an AirTag, Push down the battery compartment door: step 1, image 1 of 2 How to Drill a Keyring Hole in an AirTag, Push down the battery compartment door: step 1, image 2 of 2
    • Use both of your thumbs to push down on the battery compartment door.
  2. How to Drill a Keyring Hole in an AirTag, Rotate the battery compartment door: step 2, image 1 of 2 How to Drill a Keyring Hole in an AirTag, Rotate the battery compartment door: step 2, image 2 of 2
    • Rotate the battery compartment door counter-clockwise to unlatch it from the frame.
  3. How to Drill a Keyring Hole in an AirTag, Remove the battery compartment door: step 3, image 1 of 2 How to Drill a Keyring Hole in an AirTag, Remove the battery compartment door: step 3, image 2 of 2
    • Lift up the battery compartment door to remove it.
  4. How to Drill a Keyring Hole in an AirTag, Remove the battery: step 4, image 1 of 2 How to Drill a Keyring Hole in an AirTag, Remove the battery: step 4, image 2 of 2
    • Lift and remove the battery.
    • When you replace the battery, insert it such that the positive end is facing up.
  5. How to Drill a Keyring Hole in an AirTag, Drilling information: step 5, image 1 of 2 How to Drill a Keyring Hole in an AirTag, Drilling information: step 5, image 2 of 2
    • Do not remove the gray battery compartment. This image is for illustrative purposes only.
    • Inside the device, the circuit board and antenna frame have three notches for the clips and glue.
    • To avoid damaging the internal components, drill through the space next to a clip.
    • This is an image of an AirTag that has already been drilled through at the bottom location.
  6. How to Drill a Keyring Hole in an AirTag, Mark the hole location: step 6, image 1 of 3 How to Drill a Keyring Hole in an AirTag, Mark the hole location: step 6, image 2 of 3 How to Drill a Keyring Hole in an AirTag, Mark the hole location: step 6, image 3 of 3
    • Rotate the AirTag so that the CE marking is upright.
    • Use a marker or pen to draw a dot where you want to drill the keyring hole.
    • Draw the dot as close to the edge of the gray battery compartment as possible. This will allow you to reattach the battery compartment door while the keyring is attached.
    • The three potential drill locations are at the left (moving clockwise) end of each battery compartment clip hole.
    • You can locate our recommended drill location by drawing a dot at roughly seven o'clock.
  7. How to Drill a Keyring Hole in an AirTag, Safety information: step 7, image 1 of 1
    • Wear eye protection while using the vise, drilling the hole, and removing sharp edges.
    • Keep your hands away from the device while drilling the keyring hole.
  8. How to Drill a Keyring Hole in an AirTag, Drill the keyring hole: step 8, image 1 of 1
    • Secure the AirTag in a vise.
    • Make sure the area under your marked drill location is clear to avoid hitting the vise with the drill bit.
  9. How to Drill a Keyring Hole in an AirTag: step 9, image 1 of 1
    • Use a 1/16th inch drill bit to drill a hole through the AirTag.
  10. How to Drill a Keyring Hole in an AirTag, Remove burrs and sharp edges: step 10, image 1 of 2 How to Drill a Keyring Hole in an AirTag, Remove burrs and sharp edges: step 10, image 2 of 2
    Tool used on this step:
    File Set
    $5.99
    Buy
    • Use a metal file to remove burrs and sharp edges from the keyring hole.
    • You can also use sandpaper or a deburring tool.
    • Remove any remaining plastic particles on the AirTag before installing the keyring.
  11. How to Drill a Keyring Hole in an AirTag, Insert the keyring: step 11, image 1 of 2 How to Drill a Keyring Hole in an AirTag, Insert the keyring: step 11, image 2 of 2
    • Insert your keyring through the keyring hole.
    • You can apply Sugru or a sealant to seal both sides of the hole.
Kyle Smith
40,899 Reputation
123 Guides authored
Past 24 Hours: 8
Past 7 Days: 55
Past 30 Days: 252
All Time: 14,154
