Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Penguins are animals that inhabit the coldest regions of the world.
Tools
Parts
No parts specified.
  1. Draw a straight line. * Tip: Press SHIFT to have no problems Drag the line to the center of the drawing at the bottom.
    • Draw a straight line. * Tip: Press SHIFT to have no problems
    • Drag the line to the center of the drawing at the bottom.
    • She will still be the foot of your penguin
  2. using the Ellipse tool, draw around the line, tapping at its ends. With the Eraser tool, delete the bottom of the ellipse. With the Eraser tool, delete the bottom of the ellipse.
    • using the Ellipse tool, draw around the line, tapping at its ends.
    • With the Eraser tool, delete the bottom of the ellipse.
  3. With the Curve tool, draw a line from the center of the base to the outside of the penguin at the time you want the beak to remain. Now, click on the center of the penguin and complete the curve, defining the outline of your belly. Select the Fill Tool with Color and choose the color of your preference to paint the penguin - or your belly.
    • With the Curve tool, draw a line from the center of the base to the outside of the penguin at the time you want the beak to remain.
    • Now, click on the center of the penguin and complete the curve, defining the outline of your belly.
    • Select the Fill Tool with Color and choose the color of your preference to paint the penguin - or your belly.
  4. Select the Ellipse tool. Under Fill, select Solid color. Set your favorite colors in Color 1 and 2 to draw the penguin's eyes. (Here we use yellow and white. As a finishing touch, choose the Brush tool with the thicker texture and add it to the center of the penguin's eye. As a finishing touch, choose the Brush tool with the thicker texture and add it to the center of the penguin's eye.
    • Select the Ellipse tool. Under Fill, select Solid color. Set your favorite colors in Color 1 and 2 to draw the penguin's eyes. (Here we use yellow and white.
    • As a finishing touch, choose the Brush tool with the thicker texture and add it to the center of the penguin's eye.
You can use different colors and add details to make different species of penguin.
2 other people completed this guide.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
João Victor Miranda
31 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 66
