Introduction
W tym przewodniku dowiesz się, jak przejść na iOS 8.4.1
Zapamiętaj !! Dokonanie Jailbreak na podstawie Apple pobiera blokad bezpieczeństwa systemu, umożliwiając personalizację systemu i przeglądanie poufnych plików systemowych.
Po aktualizacji systemu Jailbreak jest usuwany z urządzenia.
    • Follow the instructions in the video
  1. Open the CYDIA application In the search engine enter the phrase "iFile" Click Install and Confirm
    • Open the CYDIA application
    • In the search engine enter the phrase "iFile"
    • Click Install and Confirm
  2. Location of needed file: / - System - Library - CoreServices Click on file: SystemVersion.plist
    • Location of needed file: / - System - Library - CoreServices
    • Click on file: SystemVersion.plist
    • Choose an option: Property List Viewer (PLIST)
    • Edit text as in the pictures (first photo is before editing, second after)
    • Save Changes
  3. After saving the changes, a copy will appear below the file. It should be removed
    • After saving the changes, a copy will appear below the file. It should be removed
    • After doing this, turn off the device.
  4. Click the Power button On the screen after the Apple logo should appear a slider about changing the version, move it to the right
    • Click the Power button
    • On the screen after the Apple logo should appear a slider about changing the version, move it to the right
    • The Apple logo will appear with a progress bar, wait for the device to start up
    • After restarting, it is no longer necessary to resume Jailbreak
  5. Run Settings Go to the General tab and then Updates You will see the upgrade to iOS 8.4.1 click Install
    • Run Settings
    • Go to the General tab and then Updates
    • You will see the upgrade to iOS 8.4.1 click Install
    • Remember when updating OTA you should have batteries charged above 50% or a device connected to the charger
  6. Follow the steps to upgrade Follow the steps to upgrade Follow the steps to upgrade
    • Follow the steps to upgrade
  7. Follow the steps of Apple
    • Follow the steps of Apple
  8. Run settings Go to the General tab, device information. And there should appear information about iOS 8.4.1
    • Run settings
    • Go to the General tab, device information. And there should appear information about iOS 8.4.1
    • Go to the "General" tab, then "Reset" and select "Reset content and settings"
    • Jailbreak has been removed due to updates so system firewalls exist
Gratulacje, urządzenie opuszczone do wersji 8.4.1
Armin Hełmiński
201 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 30
All Time: 45
