How to Darn a Sock
  1. How to Darn a Sock, How to Darn a Sock: step 1, image 1 of 2 How to Darn a Sock, How to Darn a Sock: step 1, image 2 of 2
    • Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
  2. How to Darn a Sock: step 2, image 1 of 2 How to Darn a Sock: step 2, image 2 of 2
    • Sew a running stitch around the hole to reinforce it.
    • To make a running stitch, move your needle in and out of the sock a fixed distance apart.
    • The needle is sharp; use caution and avoid poking your hand.
  3. How to Darn a Sock: step 3, image 1 of 2 How to Darn a Sock: step 3, image 2 of 2
    • Start a stitch from one side of the hole, about ½” to ⅛” away. Connect one side of the hole to the other using the thread.
    • Run parallel stitches until the hole is fully covered.
  4. How to Darn a Sock: step 4, image 1 of 2 How to Darn a Sock: step 4, image 2 of 2
    • Rotate your sock 90 degrees, then repeat step 4 to create a patch.
  5. How to Darn a Sock: step 5, image 1 of 2 How to Darn a Sock: step 5, image 2 of 2
    • Weave the extra thread into the sock's fabric, then cut the needle away from the thread.
justinHo910
145 Reputation
1 Guide authored
Past 24 Hours: 7
Past 7 Days: 43
Past 30 Days: 147
All Time: 1,227
