How to Clean and Lubricate Skateboard Bearings
  1. How to Clean and Lubricate Skateboard Bearings, How to Clean and Lubricate Skateboard Bearings: step 1, image 1 of 2 How to Clean and Lubricate Skateboard Bearings, How to Clean and Lubricate Skateboard Bearings: step 1, image 2 of 2
    • Remove the wheels from the skateboard by unscrewing the 8mm axle nuts with the adjustable wrench. Make sure to keep all your hardware organized so that nothing gets lost.
    • There should be four wheels, four nuts, and eight washers.
    Ask FixBot
  2. How to Clean and Lubricate Skateboard Bearings: step 2, image 1 of 2 How to Clean and Lubricate Skateboard Bearings: step 2, image 2 of 2
    • Pop the bearing out with a thin screwdriver. Go through the wheel to avoid damaging the bearings. Place the bearings next to the hardware.
    • Be careful not to push the screwdriver through the bearing into your hand.
    Ask FixBot
  3. How to Clean and Lubricate Skateboard Bearings: step 3, image 1 of 3 How to Clean and Lubricate Skateboard Bearings: step 3, image 2 of 3 How to Clean and Lubricate Skateboard Bearings: step 3, image 3 of 3
    • Remove the bearing shield with a knife. Starting with the inside ring is the easiest method.
    • Use caution when using sharp tools.
    Ask FixBot
  4. How to Clean and Lubricate Skateboard Bearings: step 4, image 1 of 3 How to Clean and Lubricate Skateboard Bearings: step 4, image 2 of 3 How to Clean and Lubricate Skateboard Bearings: step 4, image 3 of 3
    • Place the bearings and the shields in the container and pour mineral oil in until they are submerged. Place the lid on the container and give it a good shake.
    Ask FixBot
  5. How to Clean and Lubricate Skateboard Bearings: step 5, image 1 of 1
    • Take the bearings out and dry them off on a rag.
    Ask FixBot
  6. How to Clean and Lubricate Skateboard Bearings: step 6, image 1 of 2 How to Clean and Lubricate Skateboard Bearings: step 6, image 2 of 2
    • Take the WD-40 and spray a little bit into each bearing.
    Ask FixBot
  7. How to Clean and Lubricate Skateboard Bearings: step 7, image 1 of 3 How to Clean and Lubricate Skateboard Bearings: step 7, image 2 of 3 How to Clean and Lubricate Skateboard Bearings: step 7, image 3 of 3
    • Place the bearing shields back on the bearings by snapping them back in place.
    Ask FixBot
  8. How to Clean and Lubricate Skateboard Bearings: step 8, image 1 of 3 How to Clean and Lubricate Skateboard Bearings: step 8, image 2 of 3 How to Clean and Lubricate Skateboard Bearings: step 8, image 3 of 3
    • Place the bearings back in the wheels. Using the back part of the screwdriver is the best method.
    Ask FixBot
  9. How to Clean and Lubricate Skateboard Bearings: step 9, image 1 of 2 How to Clean and Lubricate Skateboard Bearings: step 9, image 2 of 2
    • Finally, re-assemble the skateboard.
    • Place one wheel on the truck with the washers on each side of the wheel.
    • Use the wrench to screw the nuts so that they are flush with the truck. The wheel should be able to move a little bit.
    • Repeat this step with the other three wheels.
    Ask FixBot
The last step is to re-assemble the skate board. Be sure to place the washers between the trucks and the wheel and between the wheel and the bolt.
Pikes Peak State College
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 46
All Time: 355
