Introduction
The needle that punctures the K-Cup beverage canister can sometimes become clogged with coffee particles. Take caution as this needle is very sharp and can cut skin.
Insert a paperclip or other small, sharp object into the bottom of the K-Cup Pack Holder needle compartment to clear out any debris. If debris is too dry and compact, perform this step under running water to loosen the debris
Flip K-Cup Pack Holder and repeat
With the Lid still open, locate the Puncture Needle. Insert a paperclip or other small sharp object into the Puncture Needle Holes to remove any debris trapped inside
Worked like a charm!
I was focused more on the bottom needle vs the upper needle.
Not only is the water passing through the cup now, it’s also a stronger stream.
Thank you very much for creating this ifix guide.
Once reassembled, run the brewer once or twice with just water to cleanse the system.
10 other people completed this guide.
2 Comments
The bottom needle is loose on small piece of plastic is this normal or broke?
