How to Change Broken Buttons on your Lexus Key Fob
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: step 1, image 1 of 2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: step 1, image 2 of 2
    • Place the key fob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Key Fob: step 2, image 1 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 2, image 2 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 2, image 3 of 3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Key Fob: step 3, image 1 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 3, image 2 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 3, image 3 of 3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Key Fob: step 4, image 1 of 2 How to Change Broken Buttons on your Lexus Key Fob: step 4, image 2 of 2
    • Remove the motherboard and battery to access the buttons.
  5. How to Change Broken Buttons on your Lexus Key Fob: step 5, image 1 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 5, image 2 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 5, image 3 of 3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
7 other people completed this guide.
Michael Tan
587 Reputation
3 Guides authored
Cal Poly, Team 30-3, Green Spring 2015 Member of Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Members
10 Guides authored
One Comment
useless guide
Davide - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 52
All Time: 6,146
