Introduction
Since B & W did not respond to my repair request, I decided to open the device myself to repair it.
For me it was just a blown fuse.
(original description in German)
Da B&W nicht auf meine Reparaturanfrage reagierte, habe ich mich entschlossen, dass Gerät selber zu öffnen bzw zu reparieren.
Bei mir war es nur eine defekte Sicherung.
Put the unit on its side and then remove the rubber plate from the bottom.
then unscrew the four screws (tamper-resistant Torx, but a small screwdriver is enough here).
Carefully remove the ribbon (press the clamp still in front) and lay the docking arm to one side.
Use a flat plastic tool or a blunt knife in the slot between the chrome bar and speaker cover to push the grille outward, while at the same time pressing the plastic fastener on the back side at the edge. USE CAUTION, the clips can break easily. Then slide the cover slowly to the side.
Remove the 8 philips screws from the front of the unit.
The remove the 2 smaller philips screws from the rear of the unit behind the tweeters.
Carefully pull the housing towards you to split the unit apart.
Loosen and remove the 3 cables (shown with the RED arrows in the picture)
Remove the screws from the power supply (4 pieces shown with the GREEN arrows) and remove the power supply.
Remove the screws holding the heat-conducting sheet (5 pieces shown with the YELLOW arrow).
solder the new 250V T1.6A fuse to the board
Having checked the fuse and the capacitors, I found on my two power supplies (I bought a second broken one for spare parts) that this resistor had blown or at least was without a jacket.
As such I couldn't determine the value, and as it is buried so deep in the board, I stopped the repair here.
17 other people completed this guide.
24 Comments
Mein Zeppelin schaltet sich nicht ein (die LED bleibt aus).
Also dachte ich auch, dass die Sicherung oder etwas anderes am Netzteil defekt ist. Ich habe den Zeppelin wie in dieser sehr hilfreichen Anleitung geöffnet, aber die Sicherung ist ok.
Wenn ich mit dem Multimeter die Spannung am Netzteil Ausgang messe ist diese aber 0V (zwischen allen Pins).
Bedeutet das, dass das Netzteil kaputt ist?
Falls ja, an welcher Komponente liegt das am ehesten?
Mein Sohnemann (1.5-jährig) hat auf der Rückseite des Zeppelins einen Schlüssel in den Lautsprecher hineingesteckt, den ich nun nicht mehr raus bekomme. Kann ich zu dem Schlüssel gelangen, wenn ich das Ding gemäss dieser Anleitung aufschraube oder ist es aussichtslos?
Der Zeppelin funktioniert immer noch einwandfrei.
